BIKELAND > FORUMS > ZX10R ZONE.com > Thread: anyone help with a electric prob NEW TOPIC NEW POLL POST REPLY
kiwi12
posted August 03, 2010 12:04 AM
Ok, so ive got new battery, and had my stator rewinded,
got a secound rr just in case,,
(Ive gone through 2 stators in the last 6 months, both burnt out.)
So i install the new stator, and a second hand RR known to be good,
start bike up and at idle im getting 13.9 to 14.1
start to rev bike up to 4k and then i see the volts dropping down to 12.9
but no further than that.
so i change to another RR and same again
I unplug the lights and then rev to 4k and i get about 13.8-14,1 volits.
I then unplug the RR and the bike picks up about 500 revs.
Ive got a gear postion sensor, a rev light/battery indercator, and a in line volt meter /lap timer .
also a yoshie ems.
Also i had a problem with the clutch switch, so i bypassed this a month or so ago.
Im about to go to a shop and get a auto elctric to have a look, but was hoping some one here may have a idea
cheers
what is going on in here?
extremelean
posted August 03, 2010 06:18 PM
check for dead short to ground, make sure yosh ecu and lap timers are hooked up correctly. Is hard to say without actually putting a meter on the machine
extremelean
posted August 03, 2010 06:19 PM
rewound stator may have short to ground....check regulator rectifier, make sure it is functioning properly
0.21741986274719 seconds processing time
