BIKELAND > FORUMS > ZX10R ZONE.com > Thread: want a Cali 08 zx10 fuel tank NEW TOPIC NEW POLL POST REPLY
justoyz2
Justoyz Racing
posted March 01, 2010 12:34 AM
I am looking for a mint condition California model fuel tank.
-color doesn't matter
-condition: minor dents, (send pic)
-must be a Cali model tank (tank has two additional pipes which run from
underneath)
You can email me at (justoyz1@yahoo.com or call 808-542-2496)
Ezell
2012 zx14R-blue,2012 zx14R-black, 2014 zx14Trbo, 2011 zx10R, 2007 zx10 Turbo.....
justoyz2
Justoyz Racing
posted March 16, 2010 05:43 PM
Does anyone even come to this forum anymore?
I need some help from my Cali brothern looking for this Cali model fuel tank..... Any help would be appreciated...
TedG
posted March 19, 2010 08:58 PM
Why a Cali tank?
Ted
2000 Green ZX12 sold
The fast color!!
Green 2005 ZX10R
2009 Concours Black ABS
Superman T
posted March 24, 2010 03:32 PM
TedG
posted March 27, 2010 07:28 PM
It has been winter and things will pick up once people start riding again.
Ted
The fast color!!
Green 2005 ZX10R
justoyz2
Justoyz Racing
posted March 30, 2010 11:59 AM
TedG,
There is a problem with some Ninjas; the models (any model) where the fuel tank will not whistle when sitting or after a ride, has an air fuel leakage. The tank is not pressurizing.
When this occurs, the tank will not run as fast as one that does. I learn this a while back with my 00 zx12 in Hawaii. I could out them the non Cali tank equipt zx12 up to the 1/8 mile, then it's like the fuel stop flowing. Regardless of the numbers in the fuel maps. It doesn't do it on the dyno, only on the street.
To correct this problem, add the seperator and a Cali tank; the seperator connects to the throttle bodies and the tank..... Don't ask me how it works, but it does.... On my 05 zx10 same issue, found a tank did the mod, the tank whistled and the bike went from 9:7ish@138 to 9:5ish@143.
So far I have gone 9:55@137 on the 08; trying to locate a tank to correct the problem, the should run 9:3ish@ 145 or so
TedG
posted March 31, 2010 01:06 PM
That is interesting, it seems odd that would have any effect. The tank isn't pressurized, it is in a partial vacuum. The hissing is sucking air in. The evap system is trying to take the fumes in the tank and use them. If this makes a difference you are running too lean and you need to adjust your fuel, not depend on fumes in the tank.
Ted
The fast color!!
Green 2005 ZX10R
justoyz2
Justoyz Racing
posted March 31, 2010 02:35 PM
Contrary to your view, it works the opposite, the hissing is pressure being released via the orifice in the locking mechnizim; if you open your fuel cap, you will see a small pin hole. This is where the pressure relief occurs.
I know it works, and something I have done several times. I learned of it in 2001, used this concept in 05, now in 08. You will see..... i'll post to number for you, both tickets.......
if your tank hisses, then you are good, prime example, I hurt my 07 zx10 pistion, because the tank stopped hissing, don't ask me why, it's beening doing it for, forever... one day it stopped and I hurt a piston, now it back to hissing. I am looking for an 04-07 zx10 tank aswell. minor dents don't matter... if you know anyone please direct them myway..
TedG
posted March 31, 2010 03:31 PM
I could be wrong, but there is nothing to pressurize the tank. it uses vacuum. The only way it can pressurize is just the expanding gasses in the tank itself. And if you need that, just seal off the vents. Problem with that is just the fuel being used will cause a vacuum.
I have removed the evap stuff and plugged off the extra vent and duplicated the 48 state hosing. Not saying that it is better....just lighter and less stuff.
Ted
The fast color!!
Green 2005 ZX10R
TedG
posted March 31, 2010 07:11 PM
And it could be that the vacuum is decreasing the fuel pressure and making it run leaner, which means your mixture is too rich. Or if it is pressurizing the tank it is making it run richer, One way or another you need to vent the tank normally and get the mixture right.
Ted
The fast color!!
Green 2005 ZX10R
justoyz2
Justoyz Racing
posted April 01, 2010 11:58 AM
TedG,
Just as the internal fuel tank pressurize your tank and assist in forcing the fuel pressure. I need the same thing to happen, when I use the Cali tank and connect it to the 1/4 pressure side of the throttle bodies, the bike performs better. Like I told you previously I pick up 2 tenths in the qtr and gain an avg of 4 to 5 mph.
You are entitle to what you feel is correct and that's great..... we learn from discussions, however I have proven this time and time again to work for my applications....
Thanks for the objective thoughts
Ezell
TedG
posted April 01, 2010 12:21 PM
And I am not saying you are wrong. All I am saying is you need to determine what is happening and not depend on an unknown pressure. Because the weather could work against you. I am just having a hard time understanding where the positive pressure comes from.
Ted
The fast color!!
Green 2005 ZX10R
justoyz2
Justoyz Racing
posted April 03, 2010 09:16 AM
I know exactly what's happening, the tank won't pressurize and to combat the non pressuirzation of the fuel tank, I have found the Cali model tank pressurize when connected to the throttle bodies. The differences of both tanks equal to about 2 tenths.
Like I mentioned in previous post, it doesn't matter what number you place in the map cell, it will not richen the bike....
justoyz2
Justoyz Racing
posted April 03, 2010 09:17 AM
it's okay to agree to disagree.... I have expirenced this several times and this is the fix action. You have not encountered this nor have you provided any solution to anyone....
Just because you don't understand it, doesn't mean it doesn't work.....
TedG
posted April 03, 2010 07:51 PM
I am not disagreeing with you. I truly believe that you get a couple of tenths. No argument from me. I am just asking how it is possible to get positive pressure from a vacuum. I am missing something and asking a question.
As for solutions you are right I am offering none and my only thought is understanding, and suggesting adjusting something that is more consistent. You are taking it the wrong way.
Ted
The fast color!!
Green 2005 ZX10R
0.25637102127075 seconds processing time
