BIKELAND > FORUMS > ZX10R ZONE.com > Thread: ZX-10 speed limiter NEW TOPIC NEW POLL POST REPLY
RidgeRacer
posted November 16, 2009 11:05 AM
ZX-10 speed limiter
I'm going through the ECU software to find the rev limits etc. of a 2004 ZX-10 (21175-0029) and can't find any speed limits. I found them on the 06/07 ZX-10 and 14 but can't seem to find them in this one.
Did the earlier 10s not have a speed limiter because they didn't have the power or gearing to get to 186? Is the normal rev limit in 6th in effect the speed limiter?
shiphteey
posted November 16, 2009 04:11 PM
RidgeRacer, if I'm not mistaken the earlier ones were geared near 186 from the factory hence why I don't think they were on there. We just rolled an 06/07 10R, you are very correct, it kicked in hard on the dyno at about 181 mph but the owner had a very bald tire.
The Ace Performance guys have tuned an 04/05 10R at the 9/10ths and may be able to shed some light on the topic but I'm pretty sure they didn't come with an electronic speed limiter....the 2 around my area are both geared up so I'd never be able to find out even if I topped them out, sorry.
A.
Gemini Motorcycles
shiphteey
posted November 16, 2009 05:49 PM
RR, this is from Gunner:
"Ship...... I noticed that Ridge was asking a question about the ECU on an 04/05 10R concerning speed limits in the ECU... Those model years where thought to be limited only by aero... I know that Chad Millholland broke 200 with his 04 10R more than once and all he done was more power and some gear AND aero changes... so will you let dude know he's wasting his time looking for a limit within the ECU..
Thanks man"
Gemini Motorcycles
RidgeRacer
posted November 17, 2009 08:57 AM
Thanks for the info.
justoyz2
Justoyz Racing
posted January 30, 2010 11:22 PM
exactly how do you derestrict a top speed limit on an ECU, is there a diode that needs to be replaced?
2012 zx14R-blue,2012 zx14R-black, 2014 zx14Trbo, 2011 zx10R, 2007 zx10 Turbo.....
RidgeRacer
posted January 30, 2010 11:29 PM
Well the way I do it is to reprogram or 'reflash' the ECU. It is basically just a computer and I go in and change the software.
justoyz2
Justoyz Racing
posted January 31, 2010 12:40 PM
is there a special SW that you have to use to make this happen? how are you connecting with the existing SW.... basically are you willing to share with the forum to make these changes?
RidgeRacer
posted February 01, 2010 08:41 AM
The software I use is some that I developed and wrote myself. To connect to the ECU I use a hardware device I designed and built. If you wanted to buy your own setup I know of a guy in Italy that sells the hardware for about 3,000 euros and charges about $300USD each and every time you use his software to flash an ECU.
0.23497200012207 seconds processing time
