BIKELAND > FORUMS > ZX10R ZONE.com > Thread: 2 stroke zx10r NEW TOPIC NEW POLL POST REPLY
11UTE
posted April 19, 2009 12:29 AM        Edited By: 11UTE on 19 Apr 2009 08:34
2 stroke zx10r
Target is 250 rear wheel horsepower at 9500rpm, and just shy of DOUBLE the torque of the original ZX-10R motor. This will be easily achievable, with an engine that weighs 25kg less than the outgoing four-stroke 1000cc engine.
For those interested in their own slice of two, three or four-cylinder two-stroke madness, we will be building five of these 1100cc power-valve engines,
so if a mighty 2T mill is up your street, give TSS a hoy - Steve or Wayne at info@twostrokeshop.com or offbeat@iinet.net.au - other contact details below.
We can build twins up to 1146cc; triples up to 1725cc; and fours up to 2200cc. Anyone fancy pepping up their Lotus Elise or Ariel Atom?
http://www.twostrokeshop.com/TSS1100GP.htm
Ricksgsxr
posted April 19, 2009 08:45 AM
Very interesting. Is this is track only or can be legal for street use? expected cost? when do you expect the first running motor? test data?
TedG
posted April 19, 2009 09:01 PM
I love two strokes. 250 rear wheel at 9500 might be a bit of a reach. They are going to need some more RPMs to do so and with that big of a piston is going to be rough. I hope it works, using modern injectors may help a bunch but oiling is going to be a challenge unless they try to inject oil into the bearings up though the rods and onto the piston skirts directly. I just thought of that, it could work. One could dramatically reduce the amount of oil used.
Ted
2000 Green ZX12 sold
The fast color!!
Green 2005 ZX10R
2009 Concours Black ABS
0.28522205352783 seconds processing time
