BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Clicking While Bike Is Moving Need Help. NEW TOPIC NEW POLL POST REPLY
KAWIZX10RNJ
posted June 30, 2008 04:57 AM        Edited By: KAWIZX10RNJ on 30 Jun 2008 06:01
I have a 05 ZX10R and when I took my bike out on the road a few weeks ago I hear this Clicking Sound coming from the area where my chain is. I stopped and looked and notice my chain was mad loose so i tightened it. it still clicks. i pulled the front sprocket cover to check my sprockes for wear and tare didnt see anything significant but i did notice that my chain was alittle caroded with rust. i cover my bike all the time even outside i guess water can get anywhere. I did make sure my engine wasnt knocking as well thank god lol. Does anyone have an idea what is wrong?
2005 TiTanium Kawi ZX10R
ianred1
posted June 30, 2008 06:16 AM
your chain might be worn out!!! How often do you lube it, if you look close at the o rings in the chain and they dont look wet, you should lube it.
If it isnt the chain it might be a bad wheel bearing making the clicking noise , put the bike on a rear stand and roll the tire around in neutral , and listen to find out where it is coming from.
Also check out your sprockets for wear and wheel alignment
KAWIZX10RNJ
posted June 30, 2008 06:34 AM
Thanks I'll put it on the jack stands and give that a shot. I thought about lubing the chain but hadn't got around to it. I'll post again later to let you know where it is coming from.
0.20929408073425 seconds processing time
