BIKELAND > FORUMS > ZX10R ZONE.com > Thread: New to Here.. looking for advice NEW TOPIC NEW POLL POST REPLY
CBRcrash
posted June 11, 2008 12:20 PM
What's up guys.. just looking for some advice.. I have an 05 zx10..full Akrapovic with bmc filter and Power Commander.. looking to get velocity stacks.. which are best???..any other mods I could do??. I just like to go really effin fast... thanks
salsa1
posted June 11, 2008 02:59 PM
16 tooth front sprocket
Salsa1
cbrcrash
posted June 11, 2008 03:29 PM
I was gonna ask about going down in the front and bigger in the back.. going lower in the front.. u gain low end.. but loose the top end.. .. so do nothing to the back sprocket??
GUNNER
posted June 11, 2008 03:46 PM
Coby Adams cylinder head.......... Don't ask how I would know that.
aliveagain
posted June 11, 2008 06:22 PM
For the price of velocity stacks,how much horsepower do you think you would increase it by?Not much.Work on a set of wheels.They can even be transferred to your next bike.
salsa1
posted June 12, 2008 11:08 AM        Edited By: salsa1 on 12 Jun 2008 12:55
as far as sprocket changes you need to determine what you like ; if for street use at least 1 less in front; but in junction with +2 in the rear would help..then again it will wheelie easier in first ect..just start with 1 less in front and see for yourself...
I don't miss top end..but I prefer 1/4 mile performance and have it streched out with 7" swing arm extensions...who goes 180 mph on a regular basis? I don't..and there are not much for curves where I live....I enjoy my transmission and shifting much more as I have it...I gear my ZX-10R very low...I enjoy it that way...
Have fun...
Salsa1
cbrcrash
posted June 12, 2008 02:09 PM
Thanks.. I'm actually saving up for a nice set of marchenisi wheels .. can't wait to get those.. and even though I'm not going to get much horsepower with the stcks.. what the hell.... I have nuttin elkse to blow my money on.. except girls, booze and drugs.. not in that order though
TedG
posted June 17, 2008 04:37 PM
I ride mine on twisty roads and although when I go down to sea level I can loft the front wheel in second coming out of corners, it is geared too low. I hit the rev limiter between corners, and shifting into third is just a waste. And a tooth down in front would make it worse.
Ted
2000 Green ZX12 sold
The fast color!!
Green 2005 ZX10R
2009 Concours Black ABS
Hells Dark Lord
living life, and loving it.
posted June 18, 2008 06:01 PM
depends on how twisty the roads are and what gear you want it in on corner exits...my Zx10 is geared -1 in the front, and +4 in the rear. This is obviously for the track, the one I usually ride is very tight and technical. In the mountains however it worked pretty darn good too. And it keeps me from doing the 1st-2nd shift. Once you are moving there is no need for first gear on any corner. And it does decent power wheelies out of the corners in 3rd.....heheheh
kz2zx
Nobody in Particular
posted June 19, 2008 09:03 PM
-2 +2 here, but it's a track bike. Wheelies at Buttonwillow in third, sometimes fourth (Lost Hills). Wheelies at 4100 feet MSL in third, too.
Like HDL, I'm trying to avoid shifting through neutral.
ASMA 47
WERA 147
www.dhowellbooks.com
salsa1
posted June 20, 2008 04:33 PM
-2 +15 here...hahaha..but that partly cause the Micky Thompson drag slick I run at the track yields tall gearing...on a normal tire on the streets I run -2 + 8...not much top end (135- 140) but she is a blast to ride and go thru the gears ....even just normal riding yields awesome get up and go.........the 7" swing arm extension keeps the acceleration forward...
have fun...
Salsa1
0.21415400505066 seconds processing time
