kow
posted May 13, 2008 03:03 AM
Edited By: kow on 13 May 2008 04:05
zx-10 turbo upgrades
I blew my motor with detonation with a turbo on it @ 6 psi...so i'd like to know
while my motor is appart is there some upgrades i'd be better doing?
i heard on a r-1 they bring up the oil pressure???
for the turbo pistons witch are better and what comp ratio?
any other advice would be appreciated!
ninja14
posted May 13, 2008 06:54 PM
Blew it?..........what kinda fuel did you have and where was the timing set?
I've run over 8psi in my 14.
I would seek out a pro kit - Muzzy or the like.
2006 Turbo ZX-14.
2005 V-max 20th Anniv.
kow
posted May 14, 2008 04:54 PM
timing was stock ...i had pump gas with octane booster guess its was not enuff
should have put at least c-12. it was while maping on dyno, it ran lean a bit too
and prob hotter then normal by too many dyno pull
aliveagain
posted May 19, 2008 07:29 PM
maybe look into something like this.
http://www.swaintech.com/
zrxdean
posted May 23, 2008 08:43 AM
Kow, if 6psi is truly as far as you'll push it, all you really need is a safe tuneup, meaning not leaner than 12:1, and 93 pump gas. Other than that, don't hit the limiter and you *should* be fine.
For more boost, install Muzzy or MTC turbo pistons (I like Muzzys', made by CP), stainless exhaust valves, heavy valve springs, and a recording wideband O2 sensor. That should get you 10psi on 93 pump gas. Any more than that and you will need race gas.
Caveat: opinion only, past performance not a predictor of future yields, etc etc.
Dean
GUNNER
posted May 24, 2008 06:19 AM
quote: Kow, if 6psi is truly as far as you'll push it, all you really need is a safe tuneup, meaning not leaner than 12:1, and 93 pump gas. Other than that, don't hit the limiter and you *should* be fine.
Dean
I would listen to anything this man has to say about a turbo.... DEAN you have been doing some great stuff with your 10R bro.... Rock on !!!
ninja_12r2000
posted August 03, 2008 05:55 AM
Just curious, did Moriwaki still done pistons, they was very good in those times. Wiseco ???
