BIKELAND > FORUMS > ZX10R ZONE.com > Thread: nasty handle bar vibration NEW TOPIC NEW POLL POST REPLY
06black10r
posted June 19, 2007 01:52 PM
Im new here so any help is greatly appreciated. I have a 06 ZX10R and at around 3500 to 4000 rpms I get a nasty vibration thru the bars to the point my throttle hand will go to sleep. I had a tech test drive the bike and he noticed the same thing and suggested i check here. The bar ends are stock so maybe heavier ones will help...
zx12adam
Member
posted June 20, 2007 05:41 AM
You could load the bars with buckshot, this helps alot with Z1000's.
But if the vibration is overly excessive and due to a problem it's better to fix it than to cover it up.
CBR1000RR
Best Literbike: Performance Bikes, Superbike, BIKE, MCN, Road Racing World, and Motorcycle USA
06black10r
posted June 20, 2007 10:38 PM
thx adam, the tech said something similar to the buckshot too. he also said it wasnt any diff from any other 10 he's riden out of the dealership. Its silky smooth below 3500 and past 4000. just looking for ideas really or to see if anyone else had the same issues.
Grease
posted June 21, 2007 10:52 AM
That is VERY common on the new 10Rs. Check these out:
Manic Salamander Kawasaki Bar Ends
Someone told me that the OEM ends are 178 grams. These are 390 grams! They eliminated the vibes I was getting at 4,000-5,500, but moved it so I now have it at 2,000-3,000 RPMs. I don't mind that because you are barely moving at that range.
There are several manufacturers that have weighted bar ends. Can't say about the others personally, but I hear good things about Motovation USA bar ends. They have a 270 gram and a 320 gram version.
Motovation 270 gram
Motovation 320 gram
Hope this helps.
06black10r
posted June 21, 2007 08:13 PM
thx a ton bro, much appreciated. i'll let ya know if it works.
0.26230716705322 seconds processing time
