BIKELAND > FORUMS > ZX10R ZONE.com > Thread: master cylinder 04-05 zx-10r NEW TOPIC NEW POLL POST REPLY
ninja_12r2000
posted February 23, 2007 08:16 AM
Anybody or everybody maybe change they're master cylinder on their zx-10r 2004 and 2005 for something else.
So what you put in place with which result. And yes I got steel braided lines, and I blled the brakes oftenly. But when you track session with the standard master cylinder, and when the heat coming on the brake lever almost touch the handle.
I got friends with 04 and o5 Zx-10r and they all do the same.
I hear that some body use the radial master of zx-6r or gsx, did that work well.
bovinespongiformencephalo
variant Kreutzfeldt-Jakob
posted February 23, 2007 10:26 AM
It's the piston size on the stock master that kills it. Almost nothing you do to the lines, pads, fluid, rotors or calipers will ever get you track ready brakes with that tiny pos bolted to the bar. A 19mm Brembo will work the best, but the radial pump off any other bike is likely going to fit and cost a lot less. A stock radial pump off the new 10 or a ZX6 is a good start, but if you have trouble locating one, Gixxers have a decent Nissin pump, and Yamaha has a oem version of the Brembo. You might also consider lines designed for the 06/07 10R or the radial pump equiped ZX6. Might be a better fit. For pads the Vesrah SRJL are nearly perfect in all conditions.
TedG
posted February 23, 2007 09:38 PM
This is the answer, the thing is day and night.
http://www.bikeland.org/board/viewthread.php?FID=19&TID=28726&set_time=
Ted
2000 Green ZX12 sold
The fast color!!
Green 2005 ZX10R
2009 Concours Black ABS
Big Daddy
posted February 24, 2007 12:48 AM
While the brembo is a sweet upgrade its not necessary for street riding however for the track its the wisest choice.
The 05 zx6r radial pump is just fine for the street and trackday use without any issues and is color matched to the 10's surrounding components.
Vesrah RJL pads are yet another improvement over the OEM pads that are worthy of consideration.
BD
magzx12r
posted February 24, 2007 06:44 AM
Get a Nissin 5/8" master cylinder. It is a direct replacement for the '04/'05 ZX-10R and firms up the lever a good bit. That is what I have on my 10.
Mark
'03 ZX-12R
'12 1199S
posted February 24, 2007 10:14 PM
5/8" is slightly less than 16mm. Stock is 14mm. My 06 gixxer has a 3/4" (1 rch over 19mm). I think I'd look for 3/4". I put the 19mm Brembo on my 04 10R and that was perfect.
GUNNER
posted February 25, 2007 11:45 AM
I have the 05.........636 unit on my 10R and it helped a lot. I changed to the Superbike lines and Motul fluid as well. Still got the stock pads and it's good, BUT I'm going to add the SRJLs next. You can't go wrong with Brembo anything when you're talking brakes. I went Factory 636 just because my girlfriend had a 636 at the time and the brakes were GREAT on it so I figured it would be just as good on the 10R and maybe better due to the 10R's larger rotor size. I believe the pads will be the last piece in this puzzle.
posted February 25, 2007 02:20 PM
you must be running aftermarket rotors too?
GUNNER
posted February 25, 2007 02:30 PM
NOPE the 10R and 636 have different size rotors
posted February 25, 2007 03:06 PM
are the stockers takin that much heat?
I will likely replace the ones on my 14 with galfers, they warped once already under warantee. No track use... just some street abuse.
ninja_12r2000
posted February 25, 2007 06:59 PM
Master cylinder GSX-R1000
So the cheapest way is to find a master cylinder of a GSX-R 1000 2005 and up.
Brembo master is it 400$ mainly ????
posted February 25, 2007 09:20 PM
About $275 for the cast 19x18 or 19x20.
redelk
Please... speak to the hand.
posted February 26, 2007 04:58 AM
This just got posted on the CMRA website:
BRAND NEW BREMBO 19x20 for sale. $215 shipped. If you have questions please email feco636@hotmail.com
I'd jump on this, if I already didn't have one. It will likely go pretty quick.
-Ernest Hemingway
TedG
posted February 26, 2007 08:54 PM
The Brembo is the shit. What does a 636 OEM go for. Bite the bullet and get one. The difference is day and night.
Ted
The fast color!!
Green 2005 ZX10R
redelk
posted February 26, 2007 11:56 PM
So what you put in place with which result?
I figure I'd give you a link to a loooong read, but it does offer at least one viewpoint ("answer").
http://www.bikeland.org/board//viewthread.php?FID=1&TID=17947
-Ernest Hemingway
Big Daddy
posted February 27, 2007 03:16 PM
Point is the zx6r will perform as well as the Brembo for street riding and mine cost $50 complete AND the brake switch plugs into the stock harness. Given the choice i still would choose the zx6r pump if i were buying new.
BD
TedG
posted February 27, 2007 09:17 PM
For 50 bucks you can't beat it. Only 50 new?
Ted
The fast color!!
Green 2005 ZX10R
Big Daddy
posted February 28, 2007 06:00 AM
No it wasn't new (ebay) i too enjoy quality items like the Brembo MC especially when they perform as well as they look but since my track time is minimal i didn't see a reason for it.
pumkin sold and headed to the east coast soon
BD
TedG
posted February 28, 2007 12:33 PM
I like that it is a trick piece, It was a cake walk to plug in the switch. The adjustment is what I like the most. It allows the lever to move way out.
0.33165407180786 seconds processing time
