BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Radiator drain NEW TOPIC NEW POLL POST REPLY
kawi4life
Live till you Die
posted February 12, 2007 08:43 PM
Radiator drain
I was woundering if anybody knows how to drain the fluid on an 05 zx10r.
oof440
posted February 13, 2007 05:09 AM
On the left hand side of the engine in front of the sprocket cover you will see the water pump cover. It has hoses running into it and it's pretty easy to spot. One of the bottom bolts on it will have a washer on it. This is your coolant drain. Make sure and pop the radiator cap off before you try to drain it and have your drain pan pretty far out to the side before you pull the bolt because it will shoot a stream out when you pull the bolt. Hope this helps you.
0.22817611694336 seconds processing time
