salsa1
posted September 08, 2006 01:10 PM
Edited By: salsa1 on 8 Sep 2006 16:05
2004 ZX-10R ; shift light wire to meter or ECU
Hi all:
Need to know what specific wire do you tap into for the shift light on the ZX-10R? 2004 model.
Purpose of tap is to get a RPM signal.
I am Installing a DL-32 data logger and LC-1 Wide band system and need an RPM input to draw from to then input to DL-32 data logger.
My understanding is that the shift light circuit will give me RPM pulse signal which will work. If anyone has used the tach signal straight from the tachometer would be usefull information.
Wires are specified by color code as per manual; anyone already tap into shift light or tachometer wire???
The system is from is Innovative Motorsports.
Need info if possible before last race one week from now;
Thank you in advance!!!
Salsa1
fastestbusaaround
I eat Fish...
posted September 09, 2006 05:53 PM
Tach wire located at the cluster should work just fine too...you can check with a meter though...it varies voltage with rev's.
FYYFF!!!
