BIKELAND > FORUMS > ZX10R ZONE.com > Thread: what is the real deal on the 636 master cylinder. NEW TOPIC NEW POLL POST REPLY
tigger
posted August 16, 2006 10:29 AM        Edited By: tigger on 16 Aug 2006 11:53
What is the real world advantages of replacing my 05's MC with a 636? Will I see a difference with a shorter stopping distance? or is it just the feel with a better initial bite? The 10R has good brakes its not as strong as my 954's but also its not that bad. Should I give it a shot if my 10 will never see the track?
TedG
posted August 16, 2006 07:17 PM
From what I understand the radial master cylinder offers better leverage which allows for more displacement without loosing feel. But when I went to Laguna I saw the Brembo unit an I have to have one. It is one very sweet unit.
Ted
2000 Green ZX12 sold
The fast color!!
Green 2005 ZX10R
2009 Concours Black ABS
bovinespongiformencephalo
variant Kreutzfeldt-Jakob
posted August 16, 2006 10:14 PM
The stock mc is too small. Even a non-radial pump of sufficient girth is going to make a big difference.
philmy3rdleg
posted August 17, 2006 07:27 AM
If your 10 will never see any track time? No.
tigger
posted August 17, 2006 08:40 AM
What generation 636 would be an exact fit? 1st or 2nd GEN?
posted August 17, 2006 09:08 AM
Neither, unless you do the lines too. A braided kit for the 636 will be a match though.
kz2zx
Nobody in Particular
posted August 18, 2006 08:18 AM        Edited By: kz2zx on 18 Aug 2006 09:20
I like the 636's brakes better, for sure. I think my next toy - should I continue to race the 10R - will be a Brembo m/c.
I've put some energy into the forks - I need more oil height - and it's starting to turn like the 636, but man, it wants to steer on the back wheel when I'm going spritedly, and I'm a front-wheel kind of guy - I'm OK with the wheels being out of line, but the bike is way more of a handful than the 636. I'm really coming to appreciate/understand that more and more as I get faster on it.
And sloppy brakes don't help.
philmy3rdleg
posted August 18, 2006 12:14 PM
Yah, I liked my stock 636 brakes better also. And I also liked the forks better. I'm 185 and have to use 1.0kg springs on the 10r to get it to stop bottoming at the correct sag. On the 636 .975 was the norm. I know its because I carry more speed and have to brake sooner and harder, but with 1.0kg springs its like riding on a latter around turn 2 and 8 at Willow.
posted August 18, 2006 09:33 PM
It is a bitch to ride, ain't it? The front always wants to tuck if you give it half a chance and the gutless midrange means you have to boil it like a middleweight. Fucking thing does deliver the laptimes though. I was happy with the oe brakes, still run the stock pads even (3rd set), but the damn master cylinder is a tosser. I've only done 3 things to the bike (04): Penske 3 way, Scotts damper, and the Brembo 19x20. Each mod is, in my never too humble opinion, an absolute necessity. I don't sweat the forks too much. I don't think the front wheel spends enough time on the ground to justify it.
tigger
posted August 20, 2006 07:34 PM
Can I still use my SS braided lines if I switch to the brembo MCs?
posted August 20, 2006 08:32 PM        Edited By: bovinespongiformencephalo on 20 Aug 2006 21:33
Yes if you don't mind ill fitting, twisted lines. It won't hurt anything, I ran a 02 gixxer for years like that. Worked flawlessly. If you get a set of lines made for the 636 they should work well with the Brembo. As always, your best solution is going to be custom lines. I'll try to post a pic of the set I made for my 04 with a Brembo MC. I run them outside the forks GP stylee, mostly because I change tires every time I ride the damn thing.
0.41955590248108 seconds processing time
