BIKELAND > FORUMS > ZX10R ZONE.com > Thread: 2006 ZX10R Clutch Grabs on Launch NEW TOPIC NEW POLL POST REPLY
nevillejnr
posted August 08, 2006 07:08 AM
I race a 2006 ZX10R and have a problem launching the bike off the start line. No matter what RPM I use, or trying to slip the clutch, I cant get it off the line smoothly.
It grabs very suddenly and obviously shoots the front wheel into the air.
I have no problems with it on the rest of the track, it works great, it's just getting off the start line that is an issue.
Is anyone else having the same problem, or maybe found a solution? The 05 Bike was much easier to get out of the starting blocks.
I was looking for a competition clutch to try, maybe someone has a better way forward
Thanks for the help!
Gunner
posted August 08, 2006 08:02 AM
Call Ryan Schnitz.............. If he can't help with a 10R clutch NO one can. OR perhaps Ricky Gadson
philmy3rdleg
posted August 08, 2006 03:11 PM
Someone on this site mentioned that clutches were coming from the factory with poorly soaked clutch plates. So when I installed my Factory pro Evo Shift Star and Detent Arm, I was checking out the plates and noticed the middle plates were dry and burnt. So I replaced them with some well soaked EBCs' and its much better on starts.
salsa1
posted August 08, 2006 05:23 PM        Edited By: salsa1 on 8 Aug 2006 22:03
Very very good chance ya have dry plates and fibers...thats a typical dragracing problem with ZX-10R...
I burnt mine on my ZX-10R (2004 ) last year...about a week before it started slipping my 10R was doing exactly what you describe...
all power and wheelie or bog off the line... I replaced the whole clutch to be sure once it started slipping short time after grabiness at the track experience... could have saved the plates and just ordered the fibers...$135.00 is not bad for all fibers...
You should inspect first; thats what Ryan schnitz told me to do... if not slipping during normal acceleration then you might get away with just soaking all the fibers and steel plates in oil...up to you...I would replace fibers to be sure myself...
can soak in oil , reinstall and see how she behaves if you care to...guys that have soaked clutch in oil just to see have noticed a big difference...
here is a step by step procedure link:
http://zx-10r.net/forum/showthread.php?t=12670&page=1&pp=10
just don't use barnett regardless what you find when you inspect... make sure you use OEM...
Hope that helps...
Salsa1
BryanB
posted August 09, 2006 05:10 AM
yea i also have a 06 zx10r and was havin the same problem, i took my clutch apart and my fibers were dry and steels had hot spots. i buffed the steels and soaked teh fibers in oil. Put it back to gether and it works good. But im goin to need to replace the clutch soon.
WRECKSHOP
posted August 09, 2006 02:26 PM
I done the clutch mod on my 06 and it is the 'bomb"...You have to purchase the $118.00 dollar double steel "Judder Spring" steel and then use four of the 04-05 thinner steels to get the right stack height.....You can slide the hell out of it....I'm going to the track this weekend and will tell yall how it works and what my 60ft's are !!! Tryed it in the parking lot and i left at around 7000-8000 rpms and it did not wheelie it just took off really hard barely lifting the front wheel.....
salsa1
posted August 09, 2006 05:20 PM
Let us know WRECKSHOP never heard of any clutch mod for a ZX-10R, where did you get the Judder spring steel?
Is this is the first double steel that goes in when steels are installed in clutch pack? if it works I am interested...
geting good 60 ft times is not always easy for 200 + lbs guys with the ZX-10R...tell us more detail of what you are talking about and post results if it works better with mod...where did you find this out? just asking.. sounds like a good deal if it delivers...
Salsa1
nevillejnr
posted August 09, 2006 10:26 PM
Thanks guys I will take the clutch apart and see if it's dry. Since we own a Kawasaki Dealership they shouldn't be to expensive to replace!
ZX14TR
posted August 16, 2006 03:07 AM
2006 ZX10R NEEDS A Hydraulically operated clutch features a radial mount clutch master cylinder for worry-free, silky smooth clutch operation!
salsa1
posted August 16, 2006 05:33 AM
I want thicker and wider clutch fiber plates....so what if whole it weighs 2-4 more pounds all together when all is said and done.. present clutch just does not hold up to much abuse..
My ZX-11 has had the same clutch for 14 years and been thru hell several days at the dragstrip and substantial back road abuses ... still works fine...my ZX-10R clutch crapped out in one day at the strip... what I would change are the fibers...
Transmission could shift smother...If hydraulic feature would help then it would be welcome as well...I can deal with it as is if I have to.. just not the best....
Salsa1
salsa1
posted August 22, 2006 05:11 AM
Another thing:
Lower first gear would really help ZX-10R getting off the line harder. this is available with first gear swap; expensive unless you do yourself..100 mph factory gearing must be great for circuit racing; sucks for drag racing or getting off the line hard in any racing...I am getting ready to gear down lower a third time on my ZX-10R...be going thru 6th gear in the 1/4 to make it work for me..If I was a pro would be different; guess what? I am not a pro.. have to adjust untill I get that good..lol
does ultra tall first gear all that needed for circuit racing? go figure...
tigger
posted August 22, 2006 11:29 AM        Edited By: tigger on 22 Aug 2006 12:30
Another thing:
I really don't understand that tall gear. You don't really need that tall 1st gear in a circuit. I only know of one track where you can see 1st gear. Plus, that 1st gear is too touchy when leaned over. That second gear if you approach a corner less than 80 mph it does'nt keep you in the powerband. I think the Honda's got a better useable gear ratio.
rockazona
posted September 09, 2006 07:54 PM        Edited By: rockazona on 9 Sep 2006 21:10
Does 16T front sprocket help?? I'm still breaking my 06' 10 in and the clutch is notchy, grabbing in 1st gear. I haven't even pushed it yet. Some have said it will get worse and come apart? Citing stories at dealerships. Not sure about that. Is there an after market clutch and springs for this bike that are better than stock? Why would Kawi install dry friction plates??
salsa1
posted September 10, 2006 04:40 PM        Edited By: salsa1 on 10 Sep 2006 17:40
Soak the fibers and plates in oil.. doubt if we will ever know why they have dry issues from the factory.. just fix it and move on.. never heard of tranies coming apart...just stories as far as any forum can tell ya....enjoy the bike...lower gearing is relative to what you use the bike for.. I would go at least to 16 front for sure...
Salsa1
deck8000
posted March 16, 2008 12:14 AM
I build mini sandrails with the zx10 motor. My first generation cars all had the 04-05 motor. Never had a problem with the clutch. The second generation cars have the 06 zx10 in them. The first test run for the new 2nd generation car was this weekend. I got about 100 yards from camp and it smoked the clutch. I towed the car back to camp and tore the clutch case open. all the fibers were dry with the exception of a few outers. These are 1000 pound sandrails and the 04-05 motor still has a strong clutch. This is its second season. The clutches are definately dry so tear it apart and soak it.
deck8000
posted March 16, 2008 12:17 AM
By the way my stock zx10 cars smoke any of the other stock streetbike powered cars, including the hayabusa cars!!!
posted March 16, 2008 05:11 PM        Edited By: stevewfl on 16 Mar 2008 18:16
deck8000, some pics would be especially nice
0.24466991424561 seconds processing time
