achevalier
posted August 02, 2006 04:07 PM
HELP
I do a stupid rally stupid thing today.
Shoot my bike with degreaser, and gess what it's attack the paint on side panel near the seat and for sure the side cover of the motor (clutch and on the othe side the firing stuff cover). So if anybody get the color code or receipe for the flat black of the sid panel (you know near the seat and the clutch cover copper brown or something could you give to me ???
Probably color rite got something but it's the expensive way.
Hope somebody got hint....
Yes I was on a paint supplier but doesn't have anything near those color so HELP....
Alain Chevalier
BLCKZX10R
N/A
posted August 02, 2006 05:04 PM
The flat black plastics are not painted.
achevalier
posted August 02, 2006 05:12 PM
They are paint
Yep they are.
ABS plastic doesn't look like this.
They are painted I'm sure because in other way the grease remover (Castrol as fact) wouldn't do anything to ABS..
Badly they are painted If not well a fine grain sand paper will do the job who didn't. So if you are sure of that well they're somethging I don't understand, like why the compound just don't work.
AWY thanks. If you can confirm the in formation I'll be glad.
Alain Chevalier
BLCKZX10R
N/A
posted August 02, 2006 05:34 PM
Idont know but the flat plastics on my 10 are not painted.. The clutch cover is powdercoated.
BLCKZX10R
N/A
posted August 02, 2006 05:36 PM
Sand paper is going to scrach it so dont do that !!!
cptcrunch
posted August 02, 2006 05:54 PM
it sounds like you are going to be buying some new parts soon. that stuff will act like stripper on your bike.
but you sure dont want to use sandpaper, that will make it look worse
thundermonkey
posted August 03, 2006 07:47 AM
Go to an autobody supplies store and they should be able to compare paint chips to give you something very close.I matched the green on mine at one using a camera made just for that purpose ,it will work on flat colors too as long as you have somewhat of a flat surface to "shoot"
thundermonkey
posted August 03, 2006 07:50 AM
Oh"and the black parts are painted they are black with a small amount of pearl and graphite
ninja_12r2000
posted August 03, 2006 07:51 AM
I found something on color rite for the flat black cover.
But they have nothing on the clutch cover etc.
I will scan the pain thanks.
achevalier
posted August 04, 2006 05:52 AM
No clue
Seem the only way is too go to color rite.
Nobody try other type of paint and scan etc..... with good result ???
Alain Chevalier
