lastman
posted July 19, 2006 06:56 AM
Edited By: lastman on 19 Jul 2006 08:07
Brakes again!! 2
Does the standard reservoir and hose fit OK with the Brembo master cylinder?
Do I need to adapt either or can the hose go straight on etc
PS: an old question, but I have never seen an answer to this. Can you get a matching (cable) clutch lever, or are they pretty much the same to look at?
cptcrunch
posted July 19, 2006 07:00 AM
It may not be straight on, but it should bolt up just like the stock parts do
bovinespongiformencephalo
variant Kreutzfeldt-Jakob
posted July 19, 2006 04:47 PM
The oe res hose is too big for the Brembo barb. You can use it but it might leak if you don't clamp the shit out of it.
