BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Bent header pipe NEW TOPIC NEW POLL POST REPLY
appocalypse
posted July 07, 2006 02:35 AM
Bent header pipe
I bent my header pipe( Arata full) the other day racing. Will it affect or hurt anything??? Or do i need to buy 2 header pipes from Arata. the dent is about 1/4" or maybe a little bigger.
tigger
posted July 07, 2006 08:08 AM
That's a tough call man. If you have the money to spare go ahead. Will it really affect your lap times? most likely not. Its one of those things, just like having your first dent in your brand new car. You'll get over it after 3 weeks, lol
philmy3rdleg
posted July 07, 2006 10:14 AM
You can repair it. here it a few ways 1. Half ass way. Driil a small hole and use a dent puller. then patch the hole by using a over the counter exhaust/muffler patch or weld it shut. If you weld it shut you need to know the exact type of titanium used or it won't work. 2. My way. I can use this way because I have some really high grade epoxies and urathanes I work with. I scuff up the dent, apply a superstrong epoxy with a bolt sticking out to grap on to and pull the dent. That way only works if you have a wide soft dent. then you put the pipes on and when you heat up the exhaust the epoxy will burn and release.
k bryant
Sponsor
posted July 07, 2006 11:28 AM
Doubt it will make any noticeable difference.
If it really bugs you, drill a hole 180 degrees opposite of the dent, large enough to get a blunt instrument (like 1/4" round stock). Then heat up the dented area with a rosebud or similar, while manipulating the tool through the hole to push it out. When done, simply weld up the hole.
maximus
posted July 09, 2006 03:18 PM
Im with tigger i dont believe it will cause any form of restriction, 1/4 inch is just not enough, no offense to the other suggestions, but drilling a hole in it and pulling it or repairing it is like pulling the dash on a brand new car, you might be opening a can of worms, i say get yourself a nice can honda spray polish or pledge clean it up nice and shiney and call it a day.
flite leader
posted July 10, 2006 02:08 PM
wont make any difference
aesthethic only!!!!!
if you have a friend at a body shop
they have a pneumatic dent puller
that welds itself to the dent.......usually steel or sheet metal only
then pulls the dent up & out
then you sand & buff
still a lot of effort
if you race
you will do worse eventually
save your money
good luck
bend your mind.....
or break your ass...!!
0.30167007446289 seconds processing time
