zx12adam
Member
posted April 07, 2006 05:28 PM
Edited By: zx12adam on 7 Apr 2006 18:33
06 ZX10R Actual Top Speed 170mph
Motorcycle USA did a Literbike review, had this to say about the 10's actual and indicated top speed...
"Then it was time to go for a big number. I kept the ZX-10's throttle pinned after running the quarter-mile, and it continued to pile on speed at a ridiculous rate. In seconds the speedometer was reading more than 180 mph, and then climbed slower until it hit 186 mph. Then back to 185, then 186, then 185.
What did I prove (aside from being stupid enough to go that fast)? Two things. First, the speedy Kaw's computer has the Euro-mandated 300 kph (186 mph) speed limiter, which, by the way, cuts in very gently, unlike a rev limiter. Second, when you see 186 mph on your Kawi's speedo, you're actually only traveling a paltry 170 mph, according to the VBOX, an 8.6% error."
Here's the rest of the test...
http://www.motorcycle-usa.com/Article_Page.aspx?ArticleID=3149
CBR1000RR
Best Literbike: Performance Bikes, Superbike, BIKE, MCN, Road Racing World, and Motorcycle USA
zx12adam
Member
posted April 07, 2006 05:30 PM
So the speed limiter isn't going off actual speed but indicated speed, so the literbike's tops speeds are determined by speedometer error. I'm wondering what rpm's it was turning? I'm wondering about the ZX14's actual?
CBR1000RR
posted April 07, 2006 05:46 PM
I saw 172mph indicated on the front straight.
philliprare1
posted April 07, 2006 05:58 PM
Get a GPS and check for speedo error.
zx12adam
Member
posted April 07, 2006 06:09 PM
Oopps, for the test they fitted 180 Pilot Race tires to the bikes, the Dunlop Qualifier the 10 came with is a lower tire, the Pilot is taller, more speedo error.
CBR1000RR
philliprare1
posted April 07, 2006 06:26 PM
Still fast..................
salsa1
posted April 07, 2006 09:06 PM
Speedo healer would let her run free to max out as far as top speed goes......
more interesting to me is the 04-05 ZX-10R comparo on the dyno... 04 ZX-10R shows great linearity thruout the powerband (no dips) ....not that 06 ZX-10R is awfull.. just not exactly what Kawi engineers were hoping for the 06 model...
Nothing earth shattering in differences.. informative more than anything ...good read....
Yeah I like my 04 ZX-10R... will continue to make payments as a totally satisfied customer....hehe
All these liter bikes are silly fast...
Salsa1
famous1
posted April 08, 2006 05:51 AM
well if'n you beats the shyt outta your clutches then try to do a top speed run...... what do ya expect?
bovinespongiformencephalo
variant Kreutzfeldt-Jakob
posted April 08, 2006 07:23 AM
quote: Oopps, for the test they fitted 180 Pilot Race tires to the bikes, the Dunlop Qualifier the 10 came with is a lower tire, the Pilot is taller, more speedo error.
The oe tire is a 190/55 isn't it? Wouldn't that be taller, in your theory, than a 180/55 pilot? Also, why would a taller tire cause the speedo to think the bike was going faster?
posted April 08, 2006 07:25 AM
quote: well if'n you beats the shyt outta your clutches then try to do a top speed run...... what do ya expect?
Why would a slipping clutch effect the speed limiter?
longy00000
posted April 08, 2006 10:18 AM
Well i must have read about 6 mag tests on the litre bikes now and most have GPS tagged the zx10 at between 174 and 186.1mph depending on wet/dry windy or otherwise conditions so this sounds more like clutch slip to me. If you repeatedly abuse the clutch and then continue on for a flat out run its gonna be hot, surely better to let it cool and then do a top speed run from a gentle rolling start.
posted April 08, 2006 09:22 PM
So you're saying there is no speed limiter?
nitrous347
posted April 08, 2006 10:36 PM
Edited By: nitrous347 on 9 Apr 2006 00:13
just got in from a ride about thirty minutes ago,and i had my gps strapped to the top yoke.I was going to make a top speed run but there was too much traffic.still I got it up to 160 m.p.h.on the gps,while my speedometer said 171.that was at 13,000 rpm in 4th gear . I was coming up on traffic so i had to shut her down. when I get up the balls again i'll give it another try somwhere else with less traffic.(2005 zx-10R magma red)
SVtoZX
posted April 09, 2006 08:50 AM
Edited By: SVtoZX on 9 Apr 2006 09:51
Hrm... strange stuff really. I was under the impression that the bike would not display a speed over 186mph too...... but a few weeks ago I saw an honest-to-goodness 188 "displayed" on the dash. Now, I know for a fact that my speedo/odometer are off by 7% (verified both not to long ago). Some math tells me that's a real 174... and I'd believe it. Bloody fast for a stock bike.
The strange part is that was close to 4500ft of eleveation, and the bike isn't fully broken in yet (about 1400 miles.. any bike I've ever had gets stronger untill about 3k miles). It might have been ever so slightly downhill, and the winds were fairly calm. I'm curious what would have let the speedo run over the 186 mark, if there is indeed some sort of limit. Thoughts?
fastestbusaaround
I eat Fish...
posted April 09, 2006 06:18 PM
I have a few GPS's and on the 10r and my Busa, the speedo was always out by 8.7%. R1 was only off by 1.5% or so...my 10R never could hit a true 186 on the GPS...she runs out of steam around 175...and then slowly gets to an indicated 186 whereas the Busa would pull hard right to the limiter...all 'bout TQ, Busa has it, 10R doesn't.
FYYFF!!!
brobin01
posted April 10, 2006 05:49 AM
Regarding the 188 ... I have videos of one of the Test Mags and its 188 right there in the Video on a back stretch and it was Still Pulling in RPM.
It's a bone stock of of the crate with only 250 miles on it so you know it keeps building as the miles pile on.
I have read all of the rags myself and the numbers and opinions are wide but the On Board Video tells it all.
salsa1
posted April 10, 2006 09:33 AM
"On Board Video tells it all. "
All of a one way run perhaps...
Salsa1
Eric_The_Jew
posted April 10, 2006 02:16 PM
Edited By: Eric_The_Jew on 10 Apr 2006 15:16
Interesting read Adam.
I thought the changes made to the '06 were aimed at increasing the bike's midrange power while still producing the same peak power. The article makes it seem like the '06 is more peaky in power delivery than before:
"Once wound up, it screams with an intense ferocity that'll make your eyes water. But below 8000 rpm, it actually gets out-motored by last year's bike (as seen here). Its torque peak now arrives 1200 revs sooner at 8300 rpm, but that wave is preceded by a relative lull. "
zx12adam
Member
posted April 10, 2006 02:49 PM
Very odd too.
When the 06 was 1st introduced I favored it a bit more than the outgoing model but now it's either way.
CBR1000RR
Eric_The_Jew
posted April 10, 2006 07:39 PM
Provided this guy isn't bullshitting, this should throw a stick in everybody's spokes:
http://www.zx-10r.net/forum/showthread.php?t=19942
longy00000
posted April 11, 2006 05:14 AM
My local dealer has just been setting two 06 ZX10s up for racing and according to his dyno he could get neither to go beyond 186 even though it appeared there might still be a few more revs to play with. Obviously a dyno doesnt have any ram effect but then it doesnt have any drag effect either.
So the point to this.........god knows.
But if you really must go "flat out" then a restrictor of some sort is likely to call a halt to your playtime if the conditions would have allowed you past 186.
Also spotted my 1st advert for a "derestrictor" kit for an 06 ten so maybe there is a piece of electronic witchcraft going on.
Team KRE
posted April 23, 2006 07:56 PM
We are racing a dragbike (2004 ZX10R motor) with 15/53 gearing (no speedohealer) and it reads 166 (on the cluster) in 4th gear pulls on the dyno at about 12,800 rpm. The dyno wheel registered about 110-112 mph. At the dragstrip, it will cut out at 131 or so mph which makes us think there is some type of built in speed limiter connected to the speedo because the cluster "thinks" it has reached 186 mph. Even after pushing the air shifter button, it immediately cuts out (we don't think we are able to reach sixth gear?) The bike ran 9.61 into a strong head wind and only was able to reach an actual speed of 131 before the engine started cutting out. It should be pulling to 141 in high gear at the end of the run., based upon our research and experience.
Does this make sense to anyone on the forum. I have spoken to someone from Kawasaki and although the ZX12 has a max speed of 186, he was not sure the ZX10R (04-05) had the same limiting device. Lastly, if, in fact, this is the problem, who manufactures the speedohealer? Thanks!
Drowland
posted April 25, 2006 05:19 AM
04 10R will not read past 189
Gary B
posted April 25, 2006 05:27 PM
quote: My local dealer has just been setting two 06 ZX10s up for racing and according to his dyno he could get neither to go beyond 186 even though it appeared there might still be a few more revs to play with. Obviously a dyno doesnt have any ram effect but then it doesnt have any drag effect either.
What kind of power is he getting from stock 06's?? I've heard as high as 168rwhp!
longy00000
posted April 26, 2006 03:11 AM
One bike was 161.9 and the other was 162.7 bhp rear wheel stuff both with less than 5 miles on the clock with cats and everythijg still fitted , both bikes now making near 180 rear wheel with a fullrace system and PC fitted with lots of dyno time to get it just right !
