BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Motor Oil NEW TOPIC NEW POLL POST REPLY
HON825
posted September 28, 2005 07:01 PM
Motor Oil
I was wondering if it is safe to use syntec oil during the early stage of the bike say under 1k miles? Or will it be better to use the regular motor oil first and change it syntec oil after couple of thousand miles. Will it make any difference during the break in stage?
Luke
  Ignore this member    Click here to send HON825 an AIM message.
Hells Dark Lord
living life, and loving it.
posted September 29, 2005 01:10 AM
Its all personal preferance......I ran mine on regular oil for the first 5000 miles, I iwll switch to synthetic now.......but I change oil every 1500-1800 miles with the the regular oil.
When i do trackdays I change the oil before everyone. I cnat see spending the extra money on synthetic when I change the oil as often as I do. When I am not doing the trackdays, I will use the sythentic and change it at normal intervals.
zeta xray
posted September 29, 2005 05:32 AM
Being able to extend oil change intervals is a less significant advantage of synthetic oils. Reduced friction and being able to withstand much higher temperatures are significantly more important to motorcycle riders. I changed to synthetic @ 612 miles.
It is good to be green.
hon825
posted September 30, 2005 08:18 AM
thanks for the input guys.
ikezixxer
posted September 30, 2005 03:32 PM
yep...my dealer told me changing oil at every 3k miles with regular is absolutely fine...and people who use synthetic really dont need to...he said synthetic intervals can be extended to 4-5k miles but by then you dont want to have that dirty oil in the bike...so it makes no real sense...he said if you change oil every 3k miles with regular it is perfectly fine and there isn't even a need to go changing it every 1-2k miles like many obsessive riders do...unless the bike sits for 8 months or more, then you can change it without hitting 3k miles.
philmy3rdleg
posted October 11, 2005 07:59 AM
http://www.yft.org/tex_vfr/tech/oil.htm I have completed alot of research on this subject, here is one link.
lizard
Modulator
posted October 11, 2005 01:54 PM
My bike doesn't require engine oil!
0.23171305656433 seconds processing time
