BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Is your exhaust valve (by the can) noisy? NEW TOPIC NEW POLL POST REPLY
thonczarenko
posted June 01, 2005 10:33 AM
When I start my bike you can hear it open or close; it is a squeeking noise. Anyone else?
Far Beyond Driven
mdzx10r
posted June 01, 2005 04:25 PM
Yes, mine and my buddys does this. I believe it is normal.
thonczarenko
posted June 02, 2005 08:56 AM
Ah, OK. I was going to argue with the shop manager about this.
Far Beyond Driven
ianred1
posted September 28, 2005 06:18 AM
yes , flap valve in the exhuast does sqeek alot , but its easily removed!
TimsterC
posted September 28, 2005 09:52 AM
mine's quiet, but I've not gone mad with mine. YET ! ;o)
Shiney side up,
Sticky side down.
;o)
  Ignore this member    Click here to send TimsterC an ICQ message. Click here to add 89556129 to your ICQ list. Click here to visit TimsterC's homepage. Click here to send TimsterC an AIM message.
thonczarenko
posted September 28, 2005 01:09 PM
Does the exhaust valve really help with the bottom end power, or is there little difference when disabling it?
Far Beyond Driven
ikezixxer
posted September 28, 2005 02:38 PM
same questions here? does it sound like a little coin bobbling in the engine? i hate it...i feel it when my leg touches the frame on the right side...it rumbles so slightly i can feel it through the frame and into my body and MAN IT IS ANNOYING!
Hells Dark Lord
living life, and loving it.
posted September 28, 2005 05:46 PM
only thing I hear of mine is the servo motor cycling....I dont hear the actual valve moving.....
thonczarenko
posted September 28, 2005 06:30 PM
Just when I turn on and off the ignition is when I hear it.
Far Beyond Driven
timsterc
posted September 29, 2005 07:00 AM
If you take you pillion seat off and take out the panel between the main seat and the pillion, you can see the servo motor.
With this removed, turn the bike on and you can see it move through it's full range of movement. This is supposed to happen.
What you'll also hear is the injectors priming.
Shiney side up,
Sticky side down.
;o)
0.23931694030762 seconds processing time
