BIKELAND > FORUMS > ZX10R ZONE.com > Thread: What happens if you eliminate the Valve Actuator? NEW TOPIC NEW POLL POST REPLY
Rubber Pants
posted March 13, 2005 04:31 PM
I was fartin around with the 10 and was wondering if this would mess up the computer as I have it hooked up but not attached to anything. As I have a Ackropovick pipe on. I tried to find this in the archives but found zip. Anybody tried this? I hate unnesssecary items on my bike.
"Ya Gotta Have Big Ones!"
speeddemons.com
  Ignore this member    Click here to visit Rubber Pants's homepage.
Dino
posted March 13, 2005 06:09 PM
Me too.
I'm waiting for someone in the know to tell me I can yank the whole system without losing any power. It's already lacking in that department.
uh oh
redelk
Please... speak to the hand.
posted March 14, 2005 09:39 AM
If you just remove the cables... nothing. If you dissconnect the unit at the plug, I believe the FI light comes on or you'll get some sort of error code. I have not heard of any method to actually remove the unit and to "trick" the ECU (like using jumper wires or such) into thinking it is still there.
-Ernest Hemingway
bovinespongiformencephalo
variant Kreutzfeldt-Jakob
posted March 14, 2005 01:08 PM
Too bad us Kawi riders tend towards the shallow end of the gene pool. Other makes have had some clever owner sort these things out already. Oh well, at least we have swft to tell us the obvious.
big daddy
posted March 14, 2005 03:21 PM
redlek is correct, if you unplug the unit the FI light activates. Ivan is working on a fix.
BD
KawaKatman
posted March 17, 2005 08:45 AM
I guess I'm the only one thinking "Wow this thing is fast! No need for modifications here" I'm just going to hang my head low and sneak out the back door now.
  Ignore this member    Click here to send KawaKatman an AIM message.
catd11r
posted March 23, 2005 05:34 PM
That's what I was wondering, after you put your pipe on, what do you do with the vave and cables? Do the cables come off closer to the seat? Or do you just zip tie everything up ,nice and neat? Cat.
Life's Been Good to Me!!!!!!!!!
posted March 23, 2005 10:05 PM
Pull the cover just forward of the p seat and you will see the actuator and cable ends. From there it should be easy to remove the cables completely.
catd11r
posted March 24, 2005 06:31 PM
Thank s , I knew I could find yhe answer here. Thanks I appreciate it Cat
10rmotor
posted March 26, 2005 06:44 PM
Go ahead and unplug/remove the actuator. The FI light will flash but the ECU won't care. I have the valve section of the exhaust removed on my 10R powered race car and the performance has not suffered. Pulls to 12.5 no problem.
catd11r
posted March 27, 2005 04:25 PM
Thank you threre 10R appreciate that
lizard
Modulator
posted May 10, 2005 04:06 PM
Exhaust Servo Motor Eliminators. Ivan has them instock.
http://www.ivansperformanceproducts.com/other.htm
Eric_The_Jew
posted February 17, 2006 01:38 PM
The ECU will go into failsafe mode (richen the mixture across the board) if i'm not mistaken.
D
posted February 17, 2006 02:03 PM
1/2 way down the page.
http://www.areapnolimits.com/newproducts.html
0.27932405471802 seconds processing time
