otto65
posted January 30, 2005 03:07 PM
05 600 master cylinder swap
Has anyone looked into this? Anyone know the piston size and stroke on the new 6? I saw all the parts on Kawasaki .com. Maybe I'll go to the dealership and start measuring (and pricing)stuff.
Its all part of my master plan to rule these worlds
fattkaw
posted January 30, 2005 04:55 PM
Edited By: fattkaw on 30 Jan 2005 18:39
I looked a little in to it and found it will fit but, the banjo is positioned different. it's under the cylinder which would require a new set of brake lines. the piston size should not be a issue since the 6 uses the same calipers.everything else will fit up. i just put on the galfer superbike brake lines so I'll hold off on the switch. if you price out the master let us know and if its on back order.
Marcos Peguero
posted January 31, 2005 05:56 AM
If you buy it from kawasaki or suzuki that uses the same its going to cost you more, look here:
http://braketech.com/cgi-bin/search.pl?conditions=Make,Part_Group&Part_Group=nissin&partialmatch=1&template=nissin&sortby=Make,Models¤tpage=2&resultfrom=20
I have one in my zx12r and goodrige dual lines and I had to dremmel a little piece on the lever for not to touch the lines. and make the cup holder.
canadamaxxer
posted January 31, 2005 07:19 AM
here is another option:
http://www.1888fastlap.com/store/customer/product.php?productid=17281&cat=321&page=1
Marcos Peguero
posted January 31, 2005 07:47 AM
The diference in price is the cup for brake fluid that is aprox 25 usd.
The gold one braketech.com has is very pretty.
I have the black with silver lever.
canadamaxxer
posted January 31, 2005 07:58 AM
quote: The diference in price is the cup for brake fluid that is aprox 25 usd.
I'm not so sure about needing the cup. The last time I bought master cylinders from those guys, they came with the cup, bracket and fasteners. I suspect the cup is for sale separately for crash victims.
