posted January 02, 2005 07:04 PM
Where can I get a wire chart? I'm going to install a remote starter for my bike, but I would like to have the wire configuration chart to make it easier. O B 1 you are my only help.
PBO ZX10R
posted January 03, 2005 06:27 AM
I have a starting system chart for it.Give me your email addy if it will help you.
Don't hate me because I own a 10 Hate me because you cant ride it !
posted January 03, 2005 09:21 AM
a remote starter for the 10R? really? Interesting.. I've installed one in a car, but never a bike..
____________ What business is it of yours where I'm from, Friendo?
posted January 03, 2005 10:08 AM
Better do a kickstand mod before ya put that remote start setup on - reazd of a few of these things folling offa the sidestand at idle.
posted January 03, 2005 11:28 AM
nakednatureboy@aol.com I use to work at a car audio shop before installing alarms and starters. I could do it with a test light and chasing wires but thats to much like work. It should be fairly easy considering that you don't have to pull in the clutch to start the bike. I need to get a delay relay to let the bike run through its check and for the pump to prime its self.
PBO ZX10R
posted January 03, 2005 12:22 PM
Edited By: boman on 3 Jan 2005 12:23
its on its way to you.......... ____________
posted January 03, 2005 02:11 PM
Should have it done by next week. I have alot of thing to do thi week so when I have time I'll let you guys know how well it works!
PBO ZX10R
posted January 04, 2005 09:06 PM
Because I am lazy! I always let my bike run for a minute or so before I take off. This way I can start it, then put my gear on while it is warming up? Its a time saver...........Just kidding I'm lazy.
PBO ZX10R
posted January 05, 2005 03:46 AM
I guess you are planning on bypassing the key, right? Otherwise, I can't see how it would work.
posted January 05, 2005 08:23 AM
Not a good thing to do...... Extended running at high idle without airflow melts stuff
like fairings. Put your stuff on and THEN ride, but easily for a few minutes.
When I was a dealer I saw lots of melted plastic due to just this procedure.
Doug
posted January 05, 2005 07:45 PM
so what you're saying its better to start it up then ride right that second. for a minute was a figure of speech. its more like 10 - 20 seconds.
PBO ZX10R
posted January 06, 2005 09:15 AM
Edited By: boman on 6 Jan 2005 09:16
remember if something can be modified.................
it will be done !!!
all of us mechanical minded folk have to tweak ,customize or modify.
its what we do.
why you ask ????
its just what we do......... ____________
posted January 06, 2005 01:42 PM
That's what I'm saying. Start it, let it idle for a minute or so while you get situated and go ride, moderately of course until things get up to temp. It'll warm more quickly with a light load, having the transmission in motion helps heat the oil and the whole assembly warms more evenly.
Doug
