steve massey
posted December 22, 2004 04:19 PM
handling problem
bike puls hard right on stand up or clutch up wheelies,everything is aligned straight, doesn't matter how hard you weight the left it pulls right, anyone heard of this problem........does not pull at all when both wheels are on the ground........
zeta xray
posted December 22, 2004 05:42 PM
How are you checking that everything is aligned? Are you using the factory marks on the swingarm, for example?
frEEk
posted December 22, 2004 06:35 PM
unevenly worn rear tire?
fattkaw
posted December 22, 2004 07:02 PM
road crown?
steve massey
posted December 22, 2004 07:22 PM
brand new pilot power rear tire , i use the string method for alignment , keep the feed back coming , i love this bike it's the funnest sportbike i've ever had need to figure out this problem...........
trikchop
posted December 22, 2004 08:15 PM
try standin or sitting more to the right side that should make it go left a little. your probable creating more of a problem by leaning left
Michael Lee
Purchase Ivy
posted December 22, 2004 10:49 PM
Keep both wheels on the ground
Bhaaaaaaa
bovinespongiformencephalo
variant Kreutzfeldt-Jakob
posted December 23, 2004 08:26 AM
If you get it up higher it's easier to control direction. Are you at or past the balance point or just powering it through the rev range?
FP 10R
Fast Learner
posted December 23, 2004 01:06 PM
Try it on the front wheel and see if it does the same......... just a suggestion. Sorry!
"Life is not a rehearsal so make the most of it" Carefully
boman
posted December 23, 2004 09:39 PM
quote: Keep both wheels on the ground
Bhaaaaaaa
"IMPOSSIBLE"
Don't hate me because I own a 10 Hate me because you cant ride it !
