BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Went to get my sprokets installed yesterday and the mechnic would not... NEW TOPIC NEW POLL POST REPLY
crispin
posted October 27, 2004 07:50 AM
Install the front sproket that I brought.
He would have had I told him to but he always gives his opinion.
He stated that going down in the front adds too much stress to the chain. He only recommends going up in the back. He did install my +1 in the rear for me.
He also felt that going down in the front and up in the back would be too much.
What do you all think?
04 ZX10-R Blue
slightly mod'd...
k bryant
Sponsor
posted October 27, 2004 09:17 AM
Sounds like itz simply his own opinion. Itz obviously possible to put more stress on the chain since itz a tighter radius, but I don't think itz anything to be overly concerned about going one tooth. And if you're going to a smaller chain (like a 520 kit), I would think it would be even less of an issue. For me personally, the only thing I really look at is how much stress it puts on the chain sliders on the swingarm. A smaller counter shaft sprocket will definetly wear out the sliders faster.
There's a whole slew of other things to consider like chain swing through the suspension cycle, how much slack is required, stress on the tranny/output shaft, etc. But overall, I can't imagine one tooth different from stock being an issue. Maybe one of the drag race experts can chime in with their point of view from actually changing/using them on the 10.
posted October 27, 2004 09:21 AM
A smaller sprocket on the front would put *less* stress on the output shaft I believe.
k bryant
Sponsor
posted October 27, 2004 09:50 AM
That could be true in many/most cases swft. I would think more stress overall, because itz rotating more times at a given speed, putting more stress overall on a host of components (bearings, etc.). Now I'm not talking about putting a "50T" on the countershaft... we're talking one tooth here.
The chain rotating at a sharper/exagerated arc; may not be the best situation. And causing more drag on the swingarm sliders because of the increased angle/plane of the chain creating more friction. But like in a drag racers set-up, if the bike is lowered and the chain/sprockets are more in line with the swingarm pivot (neutral), maybe itz somewhat of a mute point. But on a road racer/sportbike, where you are using 3-4 inches of swing/travel, it may be more relavent. But then the drag racer is definetly putting more abuse to it with the launches.... Hmm.... Probably need an expert to comment further. Whatz kinda funny, is I should have mentioned previously that I probably look more at what the change does to the wheelbase than anything. Thatz when the fun begins. Trying to change both front and back sprockets to come up with the desired ratio, without changing the wheelbase. Let the debate continue...
posted October 27, 2004 10:40 AM
I would agree with your surmise regarding the chain. I'm pretty happy with the 10R in stock form. When I rebuilt the ZZR1200, I spent the money to return it back to stock ratios with Kawasaki parts, to keep the driveline noise level as low as possible. Seems ta have worked!
posted October 27, 2004 03:25 PM
I reckon he was showing you how much he knows about a very little bit.
papawheelie
posted October 27, 2004 04:14 PM
It's your bike, his opinion, go to a different mechanic!!!!!!!
my .02
SP8
posted October 27, 2004 04:22 PM        Edited By: SP8 on 27 Oct 2004 17:23
Going from a 17 front to a 16 is not a issue. Most other bikes come with a 16 front stock. A 14 tooth front is a common mod on a 748 Ducati. I see no issue with going as low as 15. He's crazy if he thinks 16 is bad. Even Dan Kyle suggest a 15/41 combo for the RC51.
bovinespongiformencephalo
variant Kreutzfeldt-Jakob
posted October 27, 2004 07:38 PM
Lotsa folks run a 15 on their R1's that are 16 stock. No real issues. Your mech is right in that it is better to go up on the rear than down on the front. Less parasitic driveline losses would be the performance argument. As for being too much, I like to get rid of first gear for roadracing. I'm at +2 -1 and that just about does it.
big daddy
posted October 28, 2004 12:53 PM
O my another head mechanic ill informed!! that just can't be!!
BD
crispin
posted October 29, 2004 04:30 AM
BD
I don't really think he is ill infomrmed.
I think he is right.
1) My bike would be geared too low for trackday next week
2) The smaller bend would cause more friction, speed chain wear, and wear more on the chain rollers
3) I should gear my bike in steps (ie +1 on the rear) to get used to it and see how I like it before making drastic steps.
This guy does not work at some dealer.
He is actually the owner of the shop and the mechanic. He races every event. He is very much into bikes.
So he wasn't saying you can't put it on, he was saying that he did not recommend it for me.
I just wanted some feedback from others here.
Lately you guys have turned into slam monsters.
Whats that all about?
How about some helpful feedback for a change?
04 ZX10-R Blue
slightly mod'd...
salsa1
posted October 29, 2004 05:14 AM
I like ya crispin so don't take this wrong .Why are ya spliting hairs on this one?
I have 15 front and 41 rear and realize all ZX-10R owners may not like that set up but;... I do and that is what matters the most .
Ya sound like you might be taking a great risk?? so what if the chain or sprocket last only 20,000 miles instead of 50,000.
Takes me at least several years to go that far and the costs to replace if needed are not devastating;I take the chances gladly. I don't enjoy the ZX-10R near as much with tall gearing...
ask yourself what suits you; right?
Just my opinion; I am just saying no one has a data base of info with software or field research studies established to give you exact answers.
you know that...factors depend on how ya ride ;chain maintenance ect...
dive in..whats the worst that can normally happen??
No need to thank me I had some free time haha.
Have fun;stay alive.
Salsa1
crispin
posted October 29, 2004 06:00 AM
Thanks for your help. Believe me chain replacement, tire replacemet, gas mileage...
That stuff matters little to me.
Ridability and highsiding matter much more to me!
Can you describe how that gearing setup works for you.
Is you bike lowered? I would guess that it is as I don't think your gearing would let you ride at the normal height?
Am I right?
Since you have so much time on your hands I look forward to your enghty and detailed reply.
Thanks in advance!
04 ZX10-R Blue
slightly mod'd...
salsa1
posted October 29, 2004 07:58 AM        Edited By: salsa1 on 29 Oct 2004 10:38
If ya ask the right questions you will have a better chance of getting the right answers ;haha..... I would be glad help you more crispin if I had the track expertise you seem to need on this deal.
You will still be the ultimate judge depending how it feels and performs I believe. You can crash anyhow but you know that....
This might help;
http://www.sportrider.com/tech/146_0006_susp_dialin/
For street riding; I love having the lower gearing; no problems at all with ridability or anything mechanical that I can tell....All is fine.
Lowering the bike is to my advantage as well because my strong suit of performance besides street riding is dragracing with the ZX-10R........
Hope this helps some.
Peace.
Salsa1
zx10roger
posted October 30, 2004 09:07 PM
Damn I thought it was your bike.
crispin
posted October 31, 2004 05:28 AM
Who are you talking to?
04 ZX10-R Blue
slightly mod'd...
thonczarenko
posted October 31, 2004 05:17 PM
I am going +1 on the rear sprocket first. Then I will get a -1 sprocket for the front for open trrack days, which I will put on only for the event.
Far Beyond Driven
BIKEMIKE
posted October 31, 2004 05:39 PM        Edited By: BIKEMIKE on 31 Oct 2004 17:42
Prediction: Once you put the 16t on you'll leave it on!
thonczarenko
posted November 01, 2004 11:43 AM
Change gears like I change my underware
You may just be right! However, while I am in Florida, I am on the highway frequently. Typically traveling around 100mph and sometimes higher. If I am still doing that, I may swap for events.
Far Beyond Driven
0.44762492179871 seconds processing time
