SPROCKET
posted October 25, 2004 08:07 AM
Aluminum or steel?
Is aluminum or steel better for a rear sprocket? Pros, cons for each? Who makes the best sprockets?
AUT VINCERE AUT MORI.
top shelf
posted October 25, 2004 09:27 AM
Run steel on these bikes. You will destroy the Aluminum very quickly especially if you launch the bike hard, or bang lots of wheelies. These bikes just have too much power for an aluminum to hold up.
big daddy
posted October 25, 2004 09:34 AM
Thats a loaded question for sure.......as always proper maintenance & care for the components is key to longevity and with that said i've had great success with numerous hardened aluminum rear sprockets from AFAM/Renthal as my two fav's, however there are other brands such as Sprocket Specialties, Vortex, RRP that are reputable as well. I've managed some decent life (10-12k) out of aluminum sprockets over the years and don't mind purchasing a new complete setup every 12k. As for steel i can't comment as i've not used them much except many years ago.
BD
k bryant
Sponsor
posted October 25, 2004 01:30 PM
Aluminum on roadracers. Don't know about dragbike type abuse. Agree on the AFAM and/or Renthal brands.
papawheelie
posted October 25, 2004 02:11 PM
Hey sprocket, you seen the rear sprocket on my 7 after 2500 miles. hehehe, that oughta answer your ????
top shelf
posted October 25, 2004 03:02 PM
The few roadracers that I know racing these run steel. Remember Josh Hayes at Daytona? Yeah that was an aluminum sprocket that caused him to DNF, hence the reason they are running steel now. I too have had good success with AFAM's stuff,and can recommend their sprockets.
posted October 25, 2004 05:44 PM
Aluminum to save a few ounces!!!...lol...Steel last longer but aluminum is lighter and looks better...
TopShelf... The Turbo and Shootout DragBikes run aluminum sprockets...They put out 300-500 horse power and they are ok for a while.
trikchop
posted October 25, 2004 07:10 PM
for a while meaning 10-20 passes????????
Frankyoz
posted October 25, 2004 08:20 PM
For us mortals who need to consider practicality and life span I would say stick with steel, just my .02
bovinespongiformencephalo
variant Kreutzfeldt-Jakob
posted October 25, 2004 11:08 PM
I have 12k on a bare aluminum Sprocket Specialists cog. But that is on a bike that only makes 155 hp. It also only sees track, twisty and wheelie duty. Looks like it could go another 12k.
crispin
posted October 26, 2004 05:23 AM
I just bought an Alum sproket that has steel teeth on it.
I have not installed it yet.
04 ZX10-R Blue
slightly mod'd...
Hells Dark Lord
living life, and loving it.
posted October 26, 2004 09:55 AM
aluminum will last fine if you stay on top of chain maintence and adjustment....but aluminum sprockets are really suseptable to premature wear if you use an old chain.....if you go aluminum, I suggest you change the chain and front sprocket as well, unless they are new........
posted October 26, 2004 11:01 AM
quote: aluminum will last fine if you stay on top of chain maintence and adjustment....but aluminum sprockets are really suseptable to premature wear if you use an old chain.....if you go aluminum, I suggest you change the chain and front sprocket as well, unless they are new........
Spoken like a man of knowledge and experience.
10rmotor
posted October 26, 2004 04:58 PM
rear sprocket
If anyone wants a replacement stock rear sprocket I have one. It has about 600 miles on it.
crispin
posted October 26, 2004 06:24 PM
Edited By: crispin on 26 Oct 2004 20:09
This is what I just bought from kneedraggers.com
My mechanic said it was bad ass and he has not seen one before.
It matches our bikes perfectly.
He did not like the DID X-chain that I had him installed.
He refused to install the master link that came with it and instead gave me one of his 'rivet style' links.
He sas the "EK' chains are much better.
Either way here is a pic
04 ZX10-R Blue
slightly mod'd...
crispin
posted October 26, 2004 06:26 PM
I know I need some resizing software, I am looking...
Anyway the Gold part of the sproket is alum and the outer is steel.
Also check the carbon hugger. Nice...
04 ZX10-R Blue
slightly mod'd...
big daddy
posted October 26, 2004 06:47 PM
EK makes a comparable chain to DID but no better.
BD
k bryant
Sponsor
posted October 27, 2004 09:33 AM
First impression of that sprocket combo of 2 pieces - aluminum/steel just looks scary. Who makes that sprocket? Just curious to look at it in more detail from an engineering standpoint. I can't really tell how it mates up.
The riveted versus masterlink has been debated since time began... Personally, I use both. And all the "masterlink" combos I've used require the plate to be force/fit on (streetbike/roadracers), then the clip goes over to secure. On motocross bikes or dirt trackers, itz just slip her on there. If you're smart, you further secure the clip with safety wire. I have never lost a chain with a masterlink set-up. If someone does, it was installed wrong or they didn't take the extra pre-caution of safety wiring the clip on for added insurance. But no debate, you obviously can't go wrong with the riveted version....
posted October 27, 2004 08:17 PM
Sprocket Specialists calls that creation a "Stealth" sprocket.
big daddy
posted October 27, 2004 10:25 PM
When i was spending a lot of time on the R1-forum a few riders had this 'stealth' sprocket and actually had problems with the rivets connecting the two parts.....one had a rivet loosen and the other found the sprocket to be out of round.........YIKES!!
BD
posted October 28, 2004 06:36 AM
Out of round is very common on those. Actually, all sprockets should be checked. I've even seen Renthals with the holes drilled off-center.
SPROCKET
posted October 28, 2004 08:03 AM
Thanks for all the info everybody. I changed the front to a vortex(16t), and want something light yet very durable for the rear(40t).
papawheelie
posted October 28, 2004 09:10 AM
Speaking of sprockets. Where did you come up with that name, SPROCKET????? hahalol
big daddy
posted October 28, 2004 09:12 AM
his heads kinda jagged.
BD
posted October 29, 2004 10:57 AM
Edited By: dougmeyer on 29 Oct 2004 11:58
Pay proper attention to chain tension and and you'll have no problem with aluminum sprockets, ZX-10 or ZX-12.
Sprockets wear because the chain stretches (from being too tight) increasing the "pitch" or length between pins.
This forces the rollers to slide instead of roll in and out of the teeth. This is what causes the characteristic "hook" shape of a worn sprocket.
Doug
