BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Anybody Running the 520 Chain? NEW TOPIC NEW POLL POST REPLY
thonczarenko
posted October 19, 2004 08:58 AM
I am thinking of converting over to the 520 +1 tooth in the rear. I have this set up on my RC51 and I only had to adjust the chain twice for initial stretch. I know it is pretty strong; but is it strong enough.
Far Beyond Driven
trikchop
posted October 19, 2004 01:18 PM
mines stretched 5 inches and ive been running a 520 conv. for about 5k miles.
no worries
SPROCKET
posted October 19, 2004 02:09 PM
Don't dump the clutch too many times to pop the front tire up. My friend had an 01 r1 that he wheelied the crap out of, when it decided to let go it looked like a metal snake coming off the bike.
AUT VINCERE AUT MORI.
Hells Dark Lord
living life, and loving it.
posted October 19, 2004 03:01 PM
i know of guys running 520 conversions on their 12's.....get a good chain and sprockets if you are gonna do it....DID XVM or comperable chain....
kilrbusa
posted October 23, 2004 08:47 PM
I have a ek rx on my zx10 and i drag race it with +3 in rear and 1 down in front and its worked fine so far, it save quite a few lbs compare to the OEM parts. This is a non-oring chain and its helf up good, stretched 2 times and been fine since.
posted October 24, 2004 04:30 AM
Zhooligan did a 520 conversion on his 1361 motored 12. Even on the bottle (240+ hp) no worries. DID XVM Chain.
Hells Dark Lord
posted October 24, 2004 04:38 PM
i will prolly end up doing the conversion on the 10 as well, but it wont be for some time.....hell i cant use all the HP it makes now......lol
FP 10R
Fast Learner
posted October 24, 2004 11:37 PM
Running Renthal sprockets and Regina GP 520 chain after initial stretch of approx 10mm haven't needed to adjust it in the last 3k only down side so far is it makes a Hell of a Lot of NOISE! common to this setup apparently!
"Life is not a rehearsal so make the most of it" Carefully
  Ignore this member    Click here to visit FP 10R's homepage. Click here to send FP 10R an AIM message.
SP8
posted October 25, 2004 01:18 AM        Edited By: SP8 on 25 Oct 2004 02:18
So most guys running 520 kits are using non O-ring race chains?
rac4it
Bergie
posted October 25, 2004 04:07 AM
did anyone take weight measurements before/after for comparison?
bluedevil
posted October 25, 2004 08:04 AM
I also want to do the 520 like I did on my zx9 but not sure which spockets to use on the 10. Any recommendations?
big daddy
posted October 25, 2004 09:40 AM
I've not done a 520 conv on my 10r but on a few previous bikes with a OEM 530 setup the weight diff of a complete 520 conv W/aluminum rear was 2.5lbs.
BD
SPROCKET
posted October 25, 2004 10:48 AM
I talked to a guy that drag raced the piss out of his 10r with a 520. He never mentioned a problem with it.
rac4it
Bergie
posted October 25, 2004 11:13 AM
2lbs of rotating weight at 150+ is a substantial savings
WARBIRD
posted October 25, 2004 01:59 PM
Damn right............there is a lot of difference in drag at 150+ between a chain full of "Chain Wax" or other chain lube goooo ( and probably dirt.....) and a clean chain with one drop of Mobil 1 motor oil on each o-ring and roller........... Any disbelievers put your bike up on a stand and spin the wheel. Then spin mine...............
I'd Rather Be Roadracing.
0.27564406394958 seconds processing time
