BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Need Target A/F Ratio Help............. NEW TOPIC NEW POLL POST REPLY
SP8
posted October 03, 2004 03:00 AM
Anybody know what target A/F ratio the gives the ZX10R the best hp with a race pipe? I'm thinking I f'ed up and let my dyno guy tune my bike for good milage. I should have told him max hp. My current map ratio target is 13.2:1 to midrange, and 13:1 from midrange to redline. I know RC51s are mapped at 12.6:1 for max power with race pipes. I've also heard of a racing team going as rich as 12:1 with the ZX10R. Cars generally make max hp at 12.5:1. I'm thinking I'll go with something between 12.5:1 to 12.8:1. Just trying to get the best target for the ZX10R without wasting time. I have a TiForce full system, and PC3USB. When I remap it, I'll probably add a BMC race filter, and Ivan's TRE.
posted October 03, 2004 05:50 AM
Actually, you make best hp with the map as lean as possible. Notice I said best hp, not necessarily best power. The reason for going richer is to ward off detonation, and to fatten up the torque curve. Stoch. ratio of 12.8:1 seems to work pretty good for both top end power and a nice fat torque curve.
k bryant
Sponsor
posted October 03, 2004 03:42 PM
Nothing wrong with the A/F numbers you listed and you should have a sweet running 10.
I've done probably 500 runs on various RC51's in the 12.8 - 13.5 range with excellent results. Don't know about 12.6 for max power with race pipes. Never heard that one before. But conditions vary and whatever the pump says on a given day and a given bike is whatz best.
psycho1122
posted October 04, 2004 07:52 AM
12.7-12.9 is a good set of #'s to start with on a High Compresion Engine.
den
posted April 09, 2005 06:47 PM
have you found the best a/f ratio for the 10 ?
i tried several 12.8-13.5.
13.4 seems the best for the 10. Am i right ?
k bryant
Sponsor
posted April 10, 2005 05:00 PM
Should work fine. I wouldn't say 13.4 is the best. You're going to have some peaks & valleys on the fuel curve, so I'm not sure where you are saying 13.4 is the best. Normally we will look for the smoothest fuel graph between 12.8 - 13.5 on most engines, then look how the peak numbers react to those numbers. Most of the time, we get the best overall power within those numbers.
den
posted April 10, 2005 05:48 PM
on my island there's no dyno center, i tuned my bike with the wideband commander and pcusb, i always need trying it on streets wich is very dangerous. thanks for the info.
0.25282597541809 seconds processing time
