kz2zx
Nobody in Particular
posted October 02, 2004 07:10 AM
My Code School Report
Yesterday I did the Level 1 Keith Code School at Firebird International's West Track (Phoenix).
I had a ripping blast. I haven't had this much fun since I first learned to ride. This easily blew away my expectations of what a track was like.
Thursday night, I couldn't sleep a wink before the School. My stomach was in knots, and I threw in the towel at 3:30 am and made coffee and waffles...
I spent quite a while going over the bike assigned to me, looking at prior damage, nut-and-bolt check, etc. This bike had seen some lowsides for sure! Plenty of fairing repair - fiberglass galore on the inside.
The track at Firebird West is tight, with only a 1/3 mile back straight, and lots of slower-speed stuff. I was hoping to learn some higher-speed finesse but the fastest corners were only about 60 MPH or so. The track record is a 0:48 or so, and the instructors were able to put down 0:54-0:58s.
The first session on the track was the no-brake drill. Two laps for familiarization then go for 20 min with no brakes, fourth gear. The bike felt very similar to the ZX-10R in handling - just ever so slightly less heft while turning, and a slightly different tank and a slightly different bar angle. I felt very confident on the 208ZRs, and started running the bike into the corners deep and rolling on (the point of the drill was early cracking of the throttle and controlling the attitude of the bike with the throttle). I could feel the chassis under me - slightly undersprung, but damping was pretty good, and I could feel the extension on the gas, and my cornerspeeds were pretty high. Nothing too new here for me, except being able to see around the corner let me go in without fear. I laid down some very consistent 1:24s; mostly due to slower lapping traffic. I had some really nice railed corners though.
The second track session was about turn-in point. I had been using the same points, with about three exceptions, as the instructors marked. One of them was just too far outside in a chicane, and the other three were after straights, and I actually drove deeper and turned more past those points on my first session. I don't think I learned anything on this session, but it did point up something that I did learn on the next session. I had two gears here, third and fourth, and no brakes. I put down one of my fastest laps of the day here - I was the first one on the track and had no backmarkers for the first lap, and laid down a 1:00.29. This session flew by quickly...
The third session was about turn-in rate. I had always 'known' I should try to make a strong, positive control movement, and get the turning over quickly. What I didn't know was that what I had considered good enough wasn't... and that I was occasionally hunting for a lean-angle mid-corner. The instructor had me follow him for a few turns and I watched him snap it into corners, then the lightbulb came on, and I passed him to show him I got it. So - I learned a few things right then. The suspension's high-speed damping doesn't let it change it's extension much if the control input is over quickly and you return to a stable attitude very quickly. I could snap it in and not load the front!!! MAN, that was an enlightener! The under-springing of the bike wasn't that much of a worry all-of-a-sudden... Another thing I learned is that I can actually lean less by turning faster, and I don't need to hang off the bike as far - and yes, I was pretty far off the bike. I got a lot faster in three laps of following the instructor. I'm still shaking my head. Worth the price of admission right there.
So, I had lots of (now slightly faster) backmarkers all over the track. I took to pulling into pitrow, and launching again after a wave of slower riders had passed, just so I could get some good corners in.
Fourth session was about processing information further down the track - committing to a turn point, but already choosing the next event point (braking, turning, whatever). I had the first shot on the track and laid down a 1:00.04, though I was stiff and sore already - but was chowing potassium tablets by the fistful and drinking water by the gallon... I had lots of trouble with backmarkers this session. This session, they were turning faster, and trying to hit the straights faster, and since they were still using the turn-in markers the instructors had left out (duct-tape x's in the corners), they were using the whole width of the track in the corners. Only a few times could I pass on the outside - the carusel was one, and the drive off the slowest corner. I tried to follow the 6-foot rule the track marshal had given us, but still got yelled at when I got off the track for closing rate - excuse me? This is a racetrack... but I tried to give everyone more room next session. It sucked because it wasn't challenging at all, but I wanted to finish the day, so I just nodded and kept it zipped. I don't think I learned anything new here, but was driving off corners very hard, punishing the 208 rear - I've been looking ahead before I lean the bike for a while (I read the Twist of the Wrist years back, and learned it then).
Fifth session was 'trackday time', all gears, brakes, etc. I was first out again, and had one lap where I was playing with braking (slower lap) and one where I was not braking, but shifting and carrying more cornerspeed. I came to the conclusion that I overbrake when I use the brake, and enter corners slower than I need to. So - I need practice both braking later for the amount I brake (it was the school's bike and I had a deposit to consider, so I did brake early off the straights), and determining/sensing when to let off the brakes. I laid down a pair of 1:04s not braking, and a 1:08 when I did. Lesson learned.
But... pissing me off bigtime, I got redflagged for someone else's action. I was on the inside of the front straight, following the instructor, passing a backmarker with about 60 MPH difference, and the SOB tries to apex a slight kink in the straight, practicing his hard turn-in skill on the one "corner" he felt confident on. He crossed 40 feet of pavement to cut me off... yes, he didn't know I was there, I know. I grabbed a fistful of brake, and cut hard around him on the outside as he drove into my line, and I got redflagged for not giving him enough room - on the outside. And boy, I was pissed, but rules are rules, and I was supposed to, no matter what, give him more room. Still - what do I do at over 100 MPH and he's at 40? The instructor was there in front of me, just as fast, so it's not a question of a speed limit on the track. I guess I should have backed off and 'waited' to see what the Buell would have done - but I was tired of doing that. So, I guess I earned the talking to for choosing a bad choice and not backing off.
All in all, a really great day. No damage to anyone or the school's bike, and now I know I am serious about my desire to get on the track more, practice and race. I know I'm competitive - both in will and in ability. I know I'm fast, and more than equal to the task of piloting the bike around the track fast, and I know I have plenty of attention and confidence left over to know what the other riders are doing. I know where I have at least one soft point in my skills - the overbraking, and I know I can simply choose not to brake and hit the corners faster (but probably would be passed on the brakes by someone else). I know I can corner as hard as anyone, and learned some things about not needing to hang off or lean as much by turning in faster, and not upsetting or compressing the suspension by turning in faster.
I learned it's fun to wring the daylights out of a 600 - the revlimiter on the 636 slows you down... and I can spin the rear and lift the front on a 600 just like I can on the 10R, but it takes about 7,000 more RPM to do it.
I learned that it's always the overtaking rider's fault (Aaron Yates, you listening?), and that I should expect slower riders (especially those who have the benefit of 1 day's lessons, same as me) to do dumb things, so I really was responsible for giving him more room. I guess I understand the track marshal's concern for the closing rate, too. Even though I was trying to play with braking rates in the fourth session, I shouldn't enter a corner at double the speed of a slower rider in there ahead of me (even passing with wide margins). I don't think it will ever happen that way again outside of a school, since I should be grouped with faster riders in a trackday, and in a race - well, in a race I don't expect anyone that slow would be out there.
Man, I think I'm hooked. Peter Egan said that "Roadracing motorcycles makes heroin addiction look like a vague wish for something salty", and I think I am beginning to understand.
ASMA 47
WERA 147
www.dhowellbooks.com
k bryant
Sponsor
posted October 02, 2004 08:39 AM
Reads like you're a racer in the making. Go for it. It's absolutely one of the best things you'll ever do; regardless of how fast you are or end up being.
FP 10R
Fast Learner
posted October 05, 2004 01:36 AM
Great read, I must confess to feeling much the same and it just goes to show hanging of a bike like an APE is not the fastest way around even if it looks cool! Did you notice that when you had it altogether and smooth it felt like you were slower but it was actually the reverse? First track day I did on my Aprilia it felt like I could run faster, discussed it with others in the group over the lunch break and was told crap that I had lapped him at least twice in every session and towards the days end was actually 3.5 seconds faster than my ZX9R race bike and that is a quick bike! Its all about corner speed and being smooth the fastest racers are always the cleanest to watch. Rossi the perfect example.
"Life is not a rehearsal so make the most of it" Carefully
k bryant
Sponsor
posted October 05, 2004 01:04 PM
Wayne Gardner & Kevin Schwantz - two of the most "un-smooth" fastest racers the planet has ever seen. But with a few very special exceptions to the rule, you are indeed correct.
FP 10R
Fast Learner
posted October 05, 2004 04:16 PM
K bryant,
two good examples and probably more relevant for the machines they rode in their era peaky 2 stroke's with narrow power bands it would be interesting to see their style of riding on the current Moto GP machines and how they would fair ! ( Xaus, Checa ) stock up on the Fibreglass repair kits..........
katoom
posted October 05, 2004 05:33 PM
Wow great write up, I can't wait for my first track day!
12RPilot
posted October 06, 2004 03:53 AM
I don't have another track day until the 18th, but this sure has me pumped for it!!!
NESBA #209
JNM
posted October 06, 2004 02:51 PM
KZ2ZX, Sounds like you need to start racing bro! I have been club racing for 2 years now, with some pretty good success. I race at Loudon. I am trying to figure out how to expand on what Kerry said; because he is dead right.
Let me put it this way: I am 46, very low on cash, ran up a credit card that I vowed I never would, and my 6 year relationship with the g/f is about to implode. All because of racing! Yet I wouldn't change a thing. Our season just ended this past w/e, and all I could think about at an all day meeting at work was suspension settings for next year. It is the absolute biggest blast you will have. Find your local racing organization, get CCS or WERA license, and get out there. I'm sure that Kerry can give you much better advice than me, but I suggest starting with a smaller bike. I race a Supersport SV 650, and this leaves me enough money to still enjoy the hell out of my 10 on the street. Good Luck, and keep us posted.
CCS #428
kz2zx
posted October 06, 2004 04:54 PM
JNM,
Yeah, that's kind of where I was headed. I wanted to start with the school and have them point out any really bad habits I have, before starting trackdays.
I bought a ZX-6E a few months back that will be my first racebike. It's just old enough to run in Vintage at a few of the (not-so) local tracks, but takes modern rubber. I will be going to Arroyo Seca to try the track out and I think I will probably join the Vintage series there barring anything unforeseen.
I think I got this itch bad.
ASMA 47
WERA 147
posted October 06, 2004 05:46 PM
nice story... you've got mail..
JNM
posted October 06, 2004 06:57 PM
KZ2ZX, Sounds like a good plan. Trust me, you will be hooked. You will not regret it, and I'd be willing to bet that you will meet a whole new set of great people, while having the time of your life. Congrats and best of luck to you.
CCS #428
Michael Lee
Purchase Ivy
posted October 07, 2004 07:09 PM
Congrats
posted October 07, 2004 08:13 PM
kz's story's been punted all the way to the frontpage...
http://www.bikeland.org/home.php
