BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Sprocket Teeth? NEW TOPIC NEW POLL POST REPLY
zx1kr
posted September 05, 2004 10:50 PM
Sprocket Teeth?
I'am picking up a 520 chain & sprockets for my 10R.
Just looking to get some feedback on different ratios & how they worked for others on the board. Not looking to lose too much up top. any info appreciated.
Hells Dark Lord
living life, and loving it.
posted September 06, 2004 07:27 AM
i went down in the front, and went to a 190/55 rear and I love the combination.....
sp500
posted September 06, 2004 08:42 AM
you need viagra...
04 ZX10R
  Ignore this member    Click here to visit sp500's homepage.
Frankyoz
posted September 06, 2004 11:24 AM
I dropped one in the front and love it, I'm thinking about going up one in the rear also because I want a little bit more. Dropping one in the front will liven thins up a bit but probably not as much as you are thinking.
big daddy
posted September 06, 2004 01:10 PM
zx1kr
+2R should give the quicker accelaration but also maintain the topend your concerned about.
BD
zx1kr
posted September 06, 2004 06:09 PM
Thanks, I'm gonna go -1 on front. Looking for that little bit more oomph. The only reason I dont want to go up on the rear is, I dont want a few of my riding buddies to know what I'm changing until after I've sampled it out on them. We all run real close. Any advantage to put it on them for a little fun is all good!
big daddy
posted September 06, 2004 06:24 PM
dirty rat bastid...........me do it too :-)
BD
Frankyoz
posted September 06, 2004 10:06 PM
I feel the same way, dont like to do the mods you can see until last only exception is the steering damper
Hells Dark Lord
posted September 08, 2004 03:21 AM
steering damper was one of the first mods I did to the 10...it was a must....lol
o
posted November 03, 2004 02:55 PM
Question: Over the winter I plan on having the valves adjusted, thinner head gasket, pcIII, full akra, bmc filter and plan on a tooth down on the rear or do I leave stock? I hate not being able to rip it a 60 in first(front end lifts too easy). Would that make a difference or not and will I loss alot in the other gears? Help me with your wisdom.
PBO ZX10R
thonczarenko
posted November 04, 2004 09:17 AM
zx1kr, I would put the smaller counter shaft sprocket on first because it will make you adjust your rear wheel back further. This will help with the battle of the front wheel comming up too much.
Far Beyond Driven
big daddy
posted November 04, 2004 09:54 AM
and add stability which can't hurt, however installing a longer chain is the best bet.
BD
crispin
posted November 05, 2004 05:11 AM
BD
BD If you like track days so much I can't see you enjoying your longer bike as it will not turn in so nicely.
big daddy
posted November 05, 2004 09:23 AM
Your right Crispin its a dbl edged sword so to speak as the straight line stability is great but transitioning is slowed minimally.
The 10 is the shortest wheelbased liter bike of 04 and perhaps as short if not shorter than all the 600cc class, hence its ability to turn very quick lap times in all of the mag tests , etc, etc. It is also frontend weight biased as delivered so altering the geometry by raising or lowering the tubes or perhaps raising/lowering the rear via shims is a godsend to say the least.
When i installed the longer chain it extended the wheelbase by 19mm over the as delivered setup so as you might imagine its not given me any stability issues to date due in part to the change. I've searched for a pic of T Haydens SS bike that shows the rear axle position much farther back than stock, and for good reason. So all in all the 19mm has truely not hurt the side to side transitioning of it and as long as i can make geometry changes both F&R then i'm not too concerned.
BD
0.25961112976074 seconds processing time
