BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Brake Light loose NEW TOPIC NEW POLL POST REPLY
boman
posted August 17, 2004 07:49 PM
Brake Light loose
Any of you fellas brake light extremely loose ? I noticed the paint on the right side of the cover above the brake lamp rubbing off slightly. i removed the cover and the ears that hold the brake lamp in place are broken. The velcro on top of the lamp cant keep the cover pulled down.I will go by the dealer tomorrow and let them take a look. Lot of play in the tail section around where the licence plate holder bolts on.(orignal holder)The bolts are tight. Im not sure if this slack is normal.Take a look at yours and let me know. Thanks.
bo
  Ignore this member    Click here to send Boman an AIM message.
posted August 17, 2004 08:14 PM
Just checked, mine's fine. Whatcha been doing back there, getting carnel with your beasty?
12RPilot
posted August 18, 2004 05:31 AM
Glad you brought this up. I went and looked and my whole tail is kinda loose. Since it's a track bike, I took the signal light assembly off long ago. It really needs some fasteners back there to keep things tight. The tail light itself isn't rubbing on mine, I don't think. It's been covered with vinyl tape for quite a while now.
NESBA #209
marsh14
posted August 18, 2004 07:42 AM
The velcro doesn't hold mine down either. It sticks up a 1/4 inch.
When a man steals your wife, there is no better revenge than to let him keep her
posted August 24, 2004 07:40 AM
bump
Hells Dark Lord
living life, and loving it.
posted August 24, 2004 06:21 PM
bump again.....
posted August 24, 2004 06:24 PM
bump bump
Hells Dark Lord
posted August 24, 2004 06:25 PM
bump bump
again
0.27380180358887 seconds processing time
