BIKELAND > FORUMS > ZX10R ZONE.com > Thread: a thought... NEW TOPIC NEW POLL POST REPLY
posted August 01, 2004 09:59 AM        Edited By: swft on 1 Aug 2004 11:04
A thought...
How to wire for dual low beams / high beams:
No-one's done it yet. Would involve a fair amount of hacking to the wiring harness. UNLESS someone made a secondary harness that would plug into the two stock headlight connectors. Ie; you supply voltage for the low beam elements from one plug and voltage for high beam for the other.
STOCK:
FACTORY HARNESS ----------- LOW BEAM
----------- HIGH BEAM
MODIFIED:
FACTORY HARNESS ----------- LOW ADAPTER ----------- LOW BEAM
FACTORY HARNESS ----------- HIGH ADAPTER ----------- HIGH BEAM
bovinespongiformencephalo
variant Kreutzfeldt-Jakob
posted August 01, 2004 02:46 PM
I want what he's smoking.
beansbaxter
posted August 01, 2004 02:52 PM
It could work, I understand it. I would need a 10r to take a stab at it.
posted August 01, 2004 02:55 PM
wiring a piece of cake... I wonder if the bulb will fit the reflector though,,,
posted August 01, 2004 04:04 PM
Good question...That's the real qualifier, making the 'mechanical' stuff work.
DB
posted August 01, 2004 05:15 PM
When you professionals get it figured out and tried out let me know, I'm interested. THANKS
Dan
04 ZX10r (Track only)
08 Concours14
zeta xray
posted August 01, 2004 08:43 PM
Our bulbs are H7 bulbs, which are single filament only.....
H4 bulbs are dual filament but the base of the H4 bulb is much larger than an H7.
Wiring is not the hardest problem that has to be overcome. It is that proverbial square peg in a round hole issue.
posted August 01, 2004 09:17 PM
Yah, I know...So the 'spensive' part would be modifying the housing, or buying another one and modifying it.
zeta xray
posted August 01, 2004 09:38 PM
If you were to wind up with some donor H4 sockets, I guess you could cut up the back of the stock ZX10 headlight assembly and then epoxy or JB Weld the donor sockets into the back of the housing. But, remember our reflectors are not designed for dual lights and the RH reflector might give the low beam of the H4 bulb a high beam pattern, anyway. And most likely, the bulb would be further forward into the reflector. I don't know what effect that would have. I am not really dialed into all of the different lighting options but it would seem like the only way it could work would be to put 2 units per side that do not use the stock reflector. Something like a projector beam lights, like the R1 or Ducati 999. Of course, they would still need to be individually adjusted, etc. Hmmm
Just thinking out loud.....
posted August 01, 2004 09:39 PM
Yah, lotta work...
posted August 01, 2004 09:48 PM
Take a holesaw to it and cement in something like this:
http://www.piaa.com/Lamps/Lamp-pages/1100x.html
salsa1
posted August 03, 2004 04:34 AM        Edited By: salsa1 on 3 Aug 2004 07:01
Well I am seriously considering installing two high beams for everyday use .
I would aim one somewhat lower to not blind anyone and use as low beam. During day time or dusk I could just haver both on.
figure it will be better than what I have now.
Since I live in low traffic small town area ,(12,000 population) and don't drive much at night anyways.
I noticed when I have high beam on I am not blinding anyone with ZX-10R; just an observation..... worth a try to me .
Have fun;stay alive.
0.21899390220642 seconds processing time
