BIKELAND > FORUMS > ZX10R ZONE.com > Thread: speedohealer calculations? NEW TOPIC NEW POLL POST REPLY
salsa1
posted July 30, 2004 06:35 AM        Edited By: salsa1 on 30 Jul 2004 08:14
Speedohealer calculations?
On the ZX-10R ;using the speedohealer on line calculator I selected factory speedometer error at 7.7 % per-cent. (for estimated )
Question:
What is an average error for odometer if anyone knows??
So far:
I have used zero per-cent and tried with 7.7 per-cent for input data of estimated odometer error ; not sure what would be correct actually.
It makes a little difference on the resulting calibration value computed (which is stored in speedohealer unit). -19 % vs -18.8 %.
I went from 17 front to 15 and am using standard factory size 190 rear.
Thanks in advance!
Have fun; stay alive.
ronis
One Life... Live It!!!
posted July 30, 2004 07:01 AM
went 16T in front.
I use total correction 13.5%.
I can't say if it's very accurate as I haven't done any tests yet.
Road policemans don't care much about speeding riders in Latvia. Cagers is absolutely different case.
sp500
posted July 30, 2004 07:38 AM        Edited By: sp500 on 30 Jul 2004 08:39
stock gearing for me, did the odo test method, set -5.4%, has'nt been verified but would think this is pretty close to it.Tyre setting on 2.
04 ZX10R
  Ignore this member    Click here to visit sp500's homepage.
big daddy
posted July 30, 2004 09:14 AM
salsa disregard the ODO % and set it for speedo % as thats what we use right?
My setup is a 16t with a 180/55.
calculated @ -11%
BD
SP8
posted July 30, 2004 04:01 PM        Edited By: SP8 on 31 Jul 2004 04:50
This is a cut and paste of a my post on ZX-10R.net
I radared my bike last night. My rear tire has about 1500 miles on it. Where I live we have speed limit sign post that shows a approaching vehicles speed. I kept the bike steady at 40mph all the way past the speed detector. It posted a consistent 37mph.
So: ((40/37)-1)100=8.1081% error
I can't wait till my speedo healer gets here with my sprockets.
sp500
posted July 31, 2004 03:29 AM
calculated @ -11%
BD
This was set for the speedo calculations, not for the odo. It was however set using the odo method.
from speedohealer site.
16. What is the "Speedo-to-Odo error ratio"?
There is one speed signal which drives both the speedometer and the odometer.
However, the manufacturers make the display units such a way that the speedometers usually read high, while the odometers are quite accurate on stock vehicles.
Speedo to odo error ratio is the quotient of the indicated speed, and the speed which drives the odometer internally.
This error ratio is fixed in the dashboard logic, i.e. it's bike model specific and will be constant no matter what you change on your bike.
The speedo to odo error ratio is almost the same as the initial (factory) speedo error, considering that the odometers are usually accurate on stock vehicles.
17. How can I determine the factory speedo-to-odo error ratio on my motorcycle?
You can easily measure this with your SH:
- Switch the SH into test mode (#1 ON, the rest: OFF)
- Turn on the ignition and the RUN switch
- Press the SH's button several times until you get a high reading on your speedometer (e.g. 258 km/h)
- Start a stopper watch and reset the tripmeter at the SAME time
- Stop the stopper watch at a given distance on the tripmeter (e.g. 20.0 km)
- Turn off the ignition and set the SH into normal mode (all switches in OFF position)
Now, you have the following data:
- Indicated speed on the speedometer
- The measured distance versus time
Based on these data, you can calculate the "speed by odo" value, then you can compare the speed indicated by the speedometer and the speed which drived the odometer.
Formulas:
- Speed by odo = Distance / Time * 3600
- Error ratio = Indicated Speed / Speed by odo
In this case:
- Indicated speed = 258 km/h
- Speed by odo = 20.0 km / 293 sec * 3600 = 245.73 km/h
- Error ratio = 258 / 245.73 = 1.0499 --> +5.0 %
As you can see, the speedo to odo error ratio is +5.0% for this bike (CBR954RR).
It means that if the odometer was 100% accurate on a stock bike, then the initial (factory) speedo error would be +5.0%
04 ZX10R
salsa1
posted August 02, 2004 04:44 AM        Edited By: salsa1 on 2 Aug 2004 06:10
Thanks for responses ; . I set speedo healer according to my hand calculator using stock rpm/mph relationship and adjusting for front sprocket gear ratio change; (101 mph=13,000 rpm for reference which I get every time) seems more accurate.
field test/verification using mile markers is what I have to do to finish ; speedohealer on-line calculations don't seem near as accurate as I want. Tried it and seems unrealistic; was way off.
Another Question : Anyone have reason to believe tachometer on ZX-10R is NOT very accurate??
Thanks again guys.
posted August 02, 2004 05:50 AM
After setting mine for 8%, I put the bike on a dyno and measured true wheel speed. Was dead on at 60mph.
0.22385907173157 seconds processing time
