BIKELAND > FORUMS > ZX10R ZONE.com > Thread: rear traction NEW TOPIC NEW POLL POST REPLY
arie_i
posted July 09, 2004 01:42 PM
rear traction
During tight cornering the rear tire tends to slide even when it is warm enough.
The only change I have done to the suspension was to ease the rear spring preload by one turn.
Is there a possible chane in the suspension setup that might prevent this particular problem?
kz2zx
Nobody in Particular
posted July 09, 2004 02:38 PM
different tire?
Mine slides when I ask it to, not when I don't.
ASMA 47
WERA 147
www.dhowellbooks.com
fastxx78
posted July 09, 2004 02:53 PM
I think it is more likely your throttle
Seriously, though, what tires are you running and at what pressure?
zeta xray
posted July 09, 2004 09:34 PM
We have some local twisties with a highly "polished" surface and it is fairly easy to spin up the rear. The ZX10 hooks up better than anything else I have ridden through those turns, including the resident R6 Yamaha. Perhaps you are being much more aggressive on the throttle than you think.
arie_i
posted July 10, 2004 12:53 AM
I use the stock tires, 33 front, 36 rear.
Yesterday I rode with 3 friends of mine in the twisties - they with older bikes - and I could not keep pace with them because the rear tire was tending to skid. I never had such a problem on my zx9.
From your experience, how long does the tire take to reach working temperature at 26 C (79 F)? Perhaps the D218 takes much longer than other brands?
posted July 10, 2004 12:57 AM
The 218 sucks. Get some better tires on there.
sp500
posted July 10, 2004 05:25 AM
Could soften the compression aswell.
  Ignore this member    Click here to visit sp500's homepage.
kz2zx
posted July 10, 2004 06:41 AM
I think the 218 sucks when it has high miles. I rode mine pretty hard from miles 3000-4100, and they definitely got weird near the end.
I tried to make the front last longer, but when it started sliding and chattering even after 20 minutes of turns, I ditched it for a 208 ZR, so I have 208s on both wheels.
I think the 208s are a grippier tire, with better steering characteristics, and I like the rear spin on the 208 better than I did with the 218.
I couldn't tell you about other tires yet, sorry.
ASMA 47
WERA 147
bovinespongiformencephalo
variant Kreutzfeldt-Jakob
posted July 10, 2004 03:16 PM
Back the compression adjuster all the way out and put less air in the rear tire. Maybe 32lbs would be a start.
CanyonCarver
posted July 10, 2004 03:55 PM        Edited By: CanyonCarver on 10 Jul 2004 16:56
Beat me to it, bovine. I'm not a fan of the 218s, but less compression and less air pressure would probably help a bit. I like to run at about 30psi, but 32 would be a good place to start. If that doesn't help out, possibly try some different tires. Lots of guys seem to like the Diablo or Diablo Corsa. Me, I like the 208GPs.
theturboeffect
posted July 10, 2004 08:29 PM
Another thing to remeber is that your zx9 weighs around 30 to 40 pounds more than your 10r too. If you don't have your suspension sorted out right you will notice the extra weight missing.
posted July 10, 2004 11:44 PM
If you like the 208gps you'll love the Rennsport/Supercorsa. You can select the appropriate compound. Dunlop only distributes a hard compound through the retail channels. To get something appropriate for under 160º track temps you need to see a race distributer. I used to tolerate the cold tearing and all the other bullshit that comes from running too hard a compound. I'm done with that crap. Dunlop can whore their name to somebody else.
CanyonCarver
posted July 11, 2004 06:34 AM
Thanks for the info, Bovine. I've been seriously considering giving the Supercorsas a try the next go around. The only real problem I've had with the GPs over time has been the high(er)-speed instability issues. On my 954, it was almost unbearable. But, the 10R is so much more stable than the Honda, that it hasn't bothered me much with the Kwak.
Since you obviously have some time on the SCs, what is your feedback on quick warmup and streetability. I ride the GPs on the street as well as track, and they are great for quick warmup and really aren't ever sketchy on the street unless the roads are damp. This isn't very often where I live in SoCal, so I just don't ride when it's wet. If the SCs offer a similarly quick warmup, I'm game.
I need a new pair now to replace the stockers on the new bike before I come off injured-reserve and start riding again, so the time may be right.
0.23101711273193 seconds processing time
