BIKELAND > FORUMS > ZX10R ZONE.com > Thread: NEW Metzeler Racetec NEW TOPIC NEW POLL POST REPLY
big daddy
posted July 07, 2004 08:12 AM
Check it out homers........
http://www.metzelermoto.com/
BD
dnwhoop02
posted July 07, 2004 10:22 AM
where? I even used their search function and it comes up with 0 documents related to "racetec"
David
'04 ZX-10R
'00 SV650
  Ignore this member    Click here to send dnwhoop02 an AIM message.
big daddy
posted July 07, 2004 10:23 AM
if you are patient and let the entire front page load you'll see.
BD
dnwhoop02
posted July 07, 2004 12:25 PM
oh... I have really good popup blocking software, so I never even saw the window come up. thanks
David
'04 ZX-10R
'00 SV650
12RPilot
posted July 07, 2004 12:29 PM
MCN says: " they are a step up in class compared to the tyre they replace."
I wonder what tyre they are replacing. They still advertise the Rennsports.
NESBA #209
Erich
posted July 07, 2004 08:33 PM
Looks like a nice wet weather tire
They definately look to be Rennsport replacements given the pattern and 3 compounds.
I like that they say that you will get more consistent wear accross the tire. I loved Rennsports, my only complaint was when they would cold tear so maybe they got that squared away.
sp500
posted July 07, 2004 10:03 PM
Has anyone had rennsports? good? Use to have m1 on the rear of a SP1/RC51.
04 ZX10R
  Ignore this member    Click here to visit sp500's homepage.
big daddy
posted July 07, 2004 10:11 PM
I've used a couple of sets primarily for trackdays with solid results. It seems as though the NEW metzeler racetec is positioned to replace the Renns though.
BD
sp500
posted July 07, 2004 10:37 PM
Do the renns heat up quick, anything noteworthy about them?
04 ZX10R
big daddy
posted July 07, 2004 10:51 PM
Yeah the heat build up is fairly quick but with cold PSI @ 31F & 29R they do feel a bit squirmy until some heat is generated. The ones i used on my 02 R1 were RS2-F RS3-R 190/55 on an abrasive track in 90+ degree heat and only had a slight hint of cold tearing.
BD
dnwhoop02
posted July 08, 2004 06:21 AM
what do you mean by cold tearing?
David
'04 ZX-10R
'00 SV650
big daddy
posted July 08, 2004 06:45 AM
Mmmmmm, i'll describe it as best i can......typically it happens to a particular section of the tire ( right or left side) depending on the track that begins to tear or perhaps ever so slightly chunk and it can be due to a couple of things, ie improper PSI, improper suspension setup, and one all to common reasons is the tire hasn't come up to proper operating temp yet! and i don't mean the surface rubber, i mean the entire tire, ie the internal cords/belts, the air inside and in some cases the wheel believe it or not can create this phenomenon 'cold tearing'. The tire will not look smooth over the entire surface (edge to edge).
Perhaps someone else has a far better description than I.
BD
Erich
posted July 08, 2004 10:36 AM
Sounds like a perfect description to me.
On an interesting note, using the Supercorsas back to back with the Rennsports I noticed that the Supercorsas don't tend to do that nearly as much. Dont know why, they are supposed to be basically the same tire.
0.24484896659851 seconds processing time
