runninhorn
posted June 29, 2004 11:10 AM
Making the Turn signals running lights......
Id like to wire my front turn signals to where they are illuminated running lights--anyone ever done this? If so, what wires did you splice into? Also, id like to make the two interior accessory lights (two small inside ones) amber, and make them turn signals as well?
1)where can I get the bulbs to change them out to amber?
2)How can I wire then to be turn signals as well?
thanks......
beansbaxter
posted June 29, 2004 07:38 PM
Honda does that already stock, and it was something that I wanted to do to my 12, but never found a solution...so I'm curious to see what you/we find out here...
frEEk
posted June 29, 2004 10:24 PM
you could get bulbs pretty much anywhere.
however, you can't really make the signals into running lights. u'd need a 2 filament bulb, which means a different bulb base and an extra wire. u'd be hard pressed to do that with stock signals. i know u can get shortstalks with 3 wires tho. other option would be to use the single filament, btu have them full on in running mode, then turn em off & on in signal mode. basically the opposite from normal operation.
RichTJ99
Newbie
posted July 05, 2004 07:32 PM
I think someone turned the running lights into signals (granted thats a little backwards) on the forum here.
Admin of http://www.zx-10r.net
snake eye
posted July 06, 2004 02:32 AM
The solution :
http://www.running-lights.com/bestand-e/index.htm
NoRiscNoFun!
