BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Anyone figured out how to remove the Exhaust Servo without the FI light? NEW TOPIC NEW POLL POST REPLY
top shelf
posted June 27, 2004 08:17 PM
Uh, yeah. What I already said. I'm putting a TiForce pipe on, and want to remove the servo without the light. Anyone got it figured out yet? Thanks
CJzx-10r
posted June 27, 2004 10:22 PM
I need to know too. I installing a Tiforce on mine this week.
10rmotor
posted June 27, 2004 10:26 PM
Well, you could leave just the servo installed and connected, and remove the cable which wouldn't be connected since the valve is gone. Not the most elegant though.
Michael Lee
Purchase Ivy
posted June 27, 2004 11:45 PM
Anything unseen can be considered elegant
12RPilot
posted June 28, 2004 01:20 AM
I haven't looked into this yet but I wonder if a simple resister would be enough to fool the ECU into thinking the servo was there?
NESBA #209
posted June 28, 2004 06:38 AM
I would imagine there's a DC stepper motor involved, and a feedback loop. Just unhook the cables and leave the servo motor in place.
extremelean
posted June 28, 2004 11:49 AM
Check you service manual...page 3-76.........This might send you in the right direction.
CanyonCarver
posted June 29, 2004 04:28 AM
Hmmmm... It would appear that possibly a 4 - 6 ohm resistor might do the job?
top shelf
posted June 29, 2004 07:24 AM
Problem with leaving the motor in is the space. I need the space to mount a PC3, and the storage won;t work as it is being used for some other goodies later this year. Thanks for any help.
kz2zx
Nobody in Particular
posted June 29, 2004 09:12 AM
Gack!
Ack! Thwat!
Canyon - that's a 4-6 KOhm not Ohm (Thousand-Ohm) resistor.
ASMA 47
WERA 147
www.dhowellbooks.com
dnwhoop02
posted June 29, 2004 09:35 AM
is there any place you can relocate the servo motor (maybe under the seat somewhere)?
David
'04 ZX-10R
'00 SV650
  Ignore this member    Click here to send dnwhoop02 an AIM message.
CanyonCarver
posted June 30, 2004 03:18 AM
Oops. Dropped a "K" while typing. Kind of an important one, tho. Yep, 4-6 KOhm.
top shelf
posted June 30, 2004 08:03 AM
Canyon and Whoop-Since you guys understand electronics far better than I do, are you saying wire the resistor between the two wires connected to the servo motor and that should be all that is necessary? TIA
kz2zx
posted June 30, 2004 04:03 PM
top shelf, as plain as I can make it: Between the White lead (C) and Black lead (D), 4-6 K should make the ECU's power-on-self-test happy.
Apparently the ECU does not sample the valve position beyond the two extremes 0 and 4-6 K during normal operation.
ASMA 47
WERA 147
top shelf
posted June 30, 2004 05:48 PM
KZ Thanks a ton!
0.21442604064941 seconds processing time
