BIKELAND > FORUMS > ZX10R ZONE.com > Thread: 10R throttle play NEW TOPIC NEW POLL POST REPLY
o
posted June 24, 2004 01:35 PM
10R throttle play
Does anyone else have alot of play in throttle? Both in & out and foward & back.
PBO ZX10R
D
posted June 24, 2004 01:39 PM
Check "Search"
o
posted June 24, 2004 02:08 PM
Nothing in "search".
PBO ZX10R
D
posted June 24, 2004 02:16 PM
Dunno bro - I typed in "throttle" and 10r section and got 5 pages worth and then ":throttle play" and got 4 pages worth.
Anyway - mine had it and I adjusted it like 5 different times, seems to have stayed put for awhile now.
snake eye
posted June 24, 2004 05:44 PM
Follow the cabel down from the throttle, just below the steering you find the adjustment tool in the cabel. Peace of cake!
NoRiscNoFun!
kz2zx
Nobody in Particular
posted June 24, 2004 05:52 PM
well, if the decel cable is loose, it's under the fuel tank... and air cleaner...
ASMA 47
WERA 147
www.dhowellbooks.com
o
posted June 24, 2004 06:48 PM
Thanx I'll start there. Before I started the hunt I was woundering if that is just the way it is. Good thing its not.
PBO ZX10R
bovinespongiformencephalo
variant Kreutzfeldt-Jakob
posted June 24, 2004 09:29 PM
I think it's a cabal.
kz2zx
posted June 25, 2004 04:59 AM
Ha. Very punny.
ASMA 47
WERA 147
o
posted June 27, 2004 07:57 PM
Snake, thanks alot! I found the adjustment tool. So much better now!
PBO ZX10R
snake eye
posted June 28, 2004 08:35 AM
Great! Your welcome mate!
Was a easy job wasn't it?
NoRiscNoFun!
o
posted June 28, 2004 11:22 AM
Too easy!
PBO ZX10R
kz2zx
posted June 28, 2004 02:48 PM
that one was the accel cable, then, if you're smiling...
ASMA 47
WERA 147
o
posted October 07, 2004 06:37 PM
I found my throttle play problem. Before I would mess with the adjuster under the tank, but that was just a quick fix then it would go back. When I took my airbox off I followed the cable to the metal clip that holds the cables together. Well that clip was on wrong. I moved the clip and now the play is gone.
PBO ZX10R
posted October 07, 2004 06:44 PM
mine also has a ton of play in it...
FP 10R
Fast Learner
posted October 07, 2004 07:20 PM
Throttle play is a real pet hate of mine, KHI spec is for 6mm free play in the assembly I still think this is to much. Solution I had a 1/4 turn Moto GP throttle assembly fitted exactly the same at those on the Kawi GP bike it has a push pull system and is really exact in operation takes a little bit of getting use to as the reaction is instant pity about the cost AUS $ 1000+ but worth it .
"Life is not a rehearsal so make the most of it" Carefully
  Ignore this member    Click here to visit FP 10R's homepage. Click here to send FP 10R an AIM message.
posted October 07, 2004 08:23 PM
1/4 turn? That would be 90º. Maybe 1/8 turn.
FP 10R
Fast Learner
posted October 07, 2004 09:15 PM
BO, it's 1/4 turn check your throttle should be about 1/3+ now a 1/8th turn on my bike would be a real problem, vertical is not my best riding position!
posted October 07, 2004 10:04 PM
A typical throttle is about 75 or 80º. 90º (1/4 turn) is a step backwards.
FP 10R
Fast Learner
posted October 11, 2004 01:45 PM
BO, checked the bike on a ride Saturday and measured it exactly, it is just a fraction more than 1/8th turn so I stand corrected this equals about 40% less than standard. Certinally makes life interesting the bike is improving every ride as I get more kms on it and it loosens up a bit more, showed some poor guy on a new Honda a bit of green on the way back sunday. It amazes me how some guys loose it when you run up the inside then the outside on successive turns just playing about then blast past passing underneath into the next series of turns and gone, topped off a great day.
0.23999977111816 seconds processing time
