BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Changed front tire today NEW TOPIC NEW POLL POST REPLY
kz2zx
Nobody in Particular
posted June 19, 2004 03:24 PM
Front and rear now wearing D208ZRs.
Wow, what was the torque on that front axle nut from KMC? There used to be this combination axle-nut wrench-sparkplug wrench in the toolkit. Now there's two peices formerly associated... but I got the wheel off.
Trouble all the way around until I got it off. My front stand has been on backorder for a while from the local guy, so I stopped by Harbor Freight and picked up a couple-of cheap 1" wide ratcheting tie-down straps, and looped 'em over the garage door track at the backhanger, loosened all the bolts (the axle was a cast-aluminum BITCH), then picked up the front end.
But the tire was boatloads easier to get off than the rear, and the new one slid right on like it was greased (it wasn't...)
This bike is strange - both the front and rear used the exact same amount of weight to balance as I took off (not in the same spots, though). Wonder if the trend will continue.
The new rear felt quicker-steering, but the new front adds a falling-in off the center - past a slight lean, it really wants to carve in. I could really feel the front wheel momentum as I scrubbed it in. Tire stops better than the 218 did, too.
I think I likey... will report back from the twisties tomorrow.
ASMA 47
WERA 147
www.dhowellbooks.com
Michael Lee
Purchase Ivy
posted June 19, 2004 03:35 PM
thanks, you may have stated it already but what kind of milage did you get out of your stock tyres?
kz2zx
posted June 19, 2004 03:39 PM
4150 rear, 4530 front. I think I could have kept the front for 500 more, but it really felt awful until it got hot and stayed hot for a while, and when it started not keeping a line on rough pavement and pushing/sliding, I thought it was time for it to go. It wasnt unpredictable, (exactly the opposite - it slid in the same turns at the same spot...) but I really didn't care for the feeling.
ASMA 47
WERA 147
dnwhoop02
posted June 19, 2004 04:56 PM        Edited By: dnwhoop02 on 19 Jun 2004 17:56
I find I get about twice as many miles out of my front tire than the back....
probably 'cause it spends so much time up in the air! booyah!
ok, just kidding....
David
'04 ZX-10R
'00 SV650
  Ignore this member    Click here to send dnwhoop02 an AIM message.
kz2zx
posted June 20, 2004 08:49 AM
I like the 208 front much better - it feels more confident, and stuck to the line like glue. I was able to hit some turns I didn't like so much on the 218 front with no ill effects (chatter, skip, slide type effects).
I think I've burned through about 1/3 of the rear in 350 miles, though.
ASMA 47
WERA 147
alley cat
posted June 20, 2004 01:55 PM
changed mine also, got a 3 inch wood screw in the rear. put on a new set of corsas i had left over from the 636. same size front but 180/55 on the rear. i did not know what to expect from the smaller rear but after about 250 miles today in some tight and open riding all i can say is wow. what a nice package, total stability, great turn in ,super grip in and coming out of the corners. i really liked these tires on the 636 and they work just as well on the 10R. so i guess what i'm saying is don't think you have to stay with the 190/50. in my opinion the 180/55 handles better and you lose nothing anywhere else...
04 ZX-10R-blue(Mr. Hyde)
C/F Micron high mnt.
i refuse to go timidly thru life only to arrive safely at death...
Bill...track head
kz2zx
posted June 20, 2004 03:08 PM
I totally agree, I have a 180/55 on the rear, and I really like it.
ASMA 47
WERA 147
1bad7
posted June 21, 2004 01:30 AM
I put on supercorsa's (190/55) front and back and went to the track yesterday. the tires completely transformed an already quick steering bike, but now I don't have any problems with the front sliding. The 190/55 was noticably taller than the 180/55, with more meat on the side for corning confidence. I will post pics later of the awesome day we had yesterday. Oh by the way there was an Italian dude on an 04 R1 and I think he was a horrible rider but, he got to see what it looks like to have his ass kicked by a ZX10(boy was it ugly).
johnnyboy
posted June 21, 2004 08:08 AM
1bad7>
Gald to hear you are enjoying the black bike, you do need to send photos though. What else have you done to it?
Johnny
dnwhoop02
posted June 21, 2004 08:14 AM
kz2zx> So to change the front tire, you suspended the bike in the air using a couple of tie down straps? I need to make the same change this week, and I too am without front stand. Just trying to find the best way to hold the front end in the air without a front stand....
David
'04 ZX-10R
'00 SV650
1bad7
posted June 21, 2004 10:25 AM
Johnny> I really haven't done too much to it, I just put the Hyperpro steering damper on, took all the stickers off, changed tires and adjusted the rear damping on it. I will be getting the rims painted here shortly(after most of the track days are done), putting a double bubble on it and maybe eventually putting a pipe on it(but it just sounds soo damn good right now). So basically nothing really just enjoying the hell out of my bike.
johnnyboy
posted June 21, 2004 12:22 PM        Edited By: johnnyboy on 21 Jun 2004 13:23
1bad7>
My partner knocked the catalyst out of the exhaust because he is still deciding on which system he wants. It sounds pretty good too, he's the guy that polished his frame. Now that looks really good. Are the tyres (SuperCorsa)any cheaper there?
kz2zx
posted June 21, 2004 04:21 PM
Yes, exactly. Two 1" wide ratcheting tie-downs. Loosen the bolts first, and do it with the garage door up - it's not weight that's the problem, but the track will try to twist if the door's not up, and tear the bolts out of the backhanger. Pick the bike up evenly - the straps go under the top clamp, careful of the ignition switch. Before you lift, besure the fairing is clear...
and I'd rather have my front stand than do it this way.
ASMA 47
WERA 147
1bad7
posted June 21, 2004 10:23 PM        Edited By: 1bad7 on 22 Jun 2004 01:32
Johnny>
Most definitely, I paid 396 for SC2's front and back, mounted and balanced, the cheapest I could find with shipping was 420 +.
0.27215909957886 seconds processing time
