BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Jardine slip-on question NEW TOPIC NEW POLL POST REPLY
marsh14
posted May 25, 2004 04:05 AM
I installed my CF slip-on last night. Looks great but I can't stop it from leaking around the clamp at the botton of the s pipe. I noticed the factory one had a small insert in it right there. Was I supposed to reuse that? The directions didn't mention it. Has anyone else had this problem? Thanks in advance for your help.
When a man steals your wife, there is no better revenge than to let him keep her
dket
posted May 25, 2004 04:23 AM
This is a good one for K. Bryant . Sounds like a quality control issue . Either the directions need a revamp or you get what you pay for dealyio . I am confident he can help you out .
posted May 25, 2004 04:46 AM
Odd...I put mine on day before yesterday, had no leaks at all. You do not reuse the muffler gasket, as the inner diameter of the s bend is much smaller than the stock pipe. How have you positioned the clamp? Can you provide a pic?
marsh14
posted May 25, 2004 06:08 AM
I am at work right now. I pushed it on as far as I could.
k bryant
Sponsor
posted May 25, 2004 03:16 PM
marsh14 - that's a new one on me. The T-Bolt clamp supplied puts more than enough pressure on the slotted inlet adaptor to seal it. Not sure I understand how you "pushed it on as far as I could"? The S-Bend simply bottoms out on the collector when you slide it on. Simply install the clamp flush with the inlet tube; no further. That will cover the slots and pinch the tube shut around the collector when you tighten it down.
I just grabbed one out of stock 5 minutes ago and installed it on my own 10. No leaks. If you need another clamp, just let me know and/or contact me personally and we'll get ya fixed up.
k bryant
Sponsor
posted May 25, 2004 04:45 PM
dket - since you appear to be taking somewhat of an expert's stance on your opinion as to the issue, perhaps you can share with me your experience with my ZX10 Slip-On that you would state "you get what you pay for dealiyo"?
marsh14
posted May 25, 2004 05:19 PM
I didn't get out of work until late so I didn't check it. What I meant was that I put it on as far as it would go as you explained. It was pretty cold here this morning and I could see the exhaust coming out around the clamp. Maybe I didn't put it in the right spot. I will check tomorrow. Thanks
k bryant
Sponsor
posted May 25, 2004 05:41 PM
No problem. Let me know. Thanx for choosing our system. We're here to help.
worm~hole
posted May 25, 2004 09:30 PM
...BUZZZZZZT!!!...wrong answer...do you have one in your hands?...have you fit one on your bike?...are you having the same issues?...do you know a bunch of other guys with the same issues?...dude
who would do us harm.”
-George Orwell
DB
posted May 25, 2004 11:28 PM
dket, and you wonder why you don't get along with anyone here. Maybe it has something to do with you being so overqualified at everything.
Dan
04 ZX10r (Track only)
08 Concours14
dket
posted May 26, 2004 04:07 AM
Why ?? I don't get into slip-ons K. Bryant . They are a waste of time IMO . I was just referring Marsh14 to you with his faulty slip-on . Then all the telephone tough guys jump on your broken down wagon to try to fuel the fire .
I have heard the same comments in the past from Hindle pipe owners . This doesn't fit or that doesn't line up right . As everyone knows Hindle is another cheap pipe company .
k bryant
Sponsor
posted May 26, 2004 07:22 AM
Oh. That explains it.....
dnwhoop02
posted May 26, 2004 09:13 AM
hey... can you just grab one out of stock for me too?
David
'04 ZX-10R
'00 SV650
  Ignore this member    Click here to send dnwhoop02 an AIM message.
Rspec99
posted May 26, 2004 10:38 AM
I don't claim to be an expert by any stretch but I've been doing some research on exhausts for the ZX-10R the past week and a half. I ruled out a full system primarily because of cost, and felt that the last thing I really "need" is more top end power (especially at the expense of low to midrange performance and arrest-me-now sound levels. Plus, I need a steering damper) However, I wanted a high quality, well designed slip on that made more usable power through the powerband, and of course a less constipated, deep, litre-class rumble in the exhaust note.
From the information I could find, only Jardine, Akarpovic, Arrow, and Two Brothers published dyno charts for their slip on systems. Micron and Muzzy don't seem to quote any numbers. Unfortunately, the Two Brothers chart tells us nothing as they dyno'd the bike in two different gears, and the chart itself is plotted horsepower over mph (even so, they showed only a 2hp gain in peak) The Akra and Arrow peak numbers are higher (European bikes, different tuning maybe?) but the hp gains from the slip on exhaust are pretty much in line with what Jardine has accomplished (~4-5hp)
That said, I decided on the Jardine slip-on for several reasons:
1) Cost - the Jardine I ordered is a carbon slip on with Ti pipe, Akras and Arrows have a stainless steel midpipe and cost a fair bit more than the deal I got. (Muzzy offers a Ti pipe as well, but it was $100 more than what I could get the Jardine for)
2) Availability - Not just initial purchase availability, but from what I am hearing, it is fairly easy to get parts if need be. People have also commented on excellent customer service which is important to me.
3) Quality - I'll have to post a addendum to this once I actually receive my pipe. Board members who have the slip on seem to rave about the attention to detail.
4) Sound - Those who have heard the Jardine's describe a deep, throaty tone. I'm not interested in a raspy twang.
5) Performance - From dyno charts, it seems the Jardine never dipped below stock numbers, but ramped up gains from a usable 3k rpm and never looks back. However, would you feel 4hp more when you already have 150+ to play with?
Anyhow, that's my take so far. I am in no way affiliated with Jardine and personally I am struggling with the fact that I am buying pipes for my Kawi from a company who also makes exhausts for cruisers and trucks (yikes!).
My slip on should arrive this weekend, so I'll hopefully post some actual experiences, and maybe a pic or sound bite if someone is willing to host it.
1bad7
posted May 26, 2004 10:57 AM
Rspec99> Don't forget that they also make the pipes for the honda factory team and quite a few others. I also am in no way affiliated with KB or Jardine, and I don't even have one of their pipes(yet) they do however, sponsor this site and from what I have witnessed first hand from others close to me, have extremely good customer service. Now if I could just get KB to send me of his pipes (ti) I would also be able to tell first hand how good they are.
dnwhoop02
posted May 26, 2004 11:05 AM
K Bryant>
Do ya'll have any plans to come out with a high-mount slip-on? I really want to go with Jardine, but if I were to buy something in the next month I'd have to limit my decision to those manufacturers who offer a high-mount. So far I've only seen one from Micron and Devil... Micron- heard these have a raspy tone, not what I'm looking for.... Devil- Don't know much about these
David
'04 ZX-10R
'00 SV650
redelk
Please... speak to the hand.
posted May 26, 2004 03:44 PM
These are the two that are the main reasons behind the majority of my bike (and even non-bike)purchases...
3) Quality - Board members who have the slip on seem to rave about the attention to detail.
After my CF slip on arrived, I was stunned to the amount of attention that was put into almost every detail of the system (the clamp bolt could have been shorter). It's easy to see why Honda uses Jardine since the fit and finish of the canister is equal to the almost sterile, perfection Honda has long been known for.
Installation was less than 10 minutes, including a smoke break between getting the tools and actually installing the pipe.
I have enjoyed outstanding service and customer support from Muzzy with both the CF/Ti system and the damper on my 12R. That is why I'm getting another damper from Muzzy for my 10R (even though I was real tempted to get an Ohlins).
Having the chance to actually met and ride with Mr. Bryant (Doug hates it when I refer to him as Mr. Meyer and I figure Kerry will too ), I knew that his commitment to customer satisfaction and quality is every bit as high as Muzzy's. Though I would have never imagined having a Jardine system on anything I owned that was green, I have no doubt that I will be pleased with my choice for many years to come.
I can also assure you that if the above is not true, I'll let ya'll know. I don't see it happening though. Anytime someone of Kerry's or Doug's position takes interest in the satisfaction of the end using customer instead of telling us to just call their "customer support folks", the odds of having an unreconcilable problem is less than zero.
Thank you Kerry for bringing another quality product option to the 10R owners' table.
-Ernest Hemingway
posted May 26, 2004 03:47 PM
posted by dket...
zx10Roger
posted May 26, 2004 04:19 PM
Damn is this dude high or what? Has he even seen the Jardine?I love mine.Damn dude no wonder no one likes you around here.
DB
posted May 26, 2004 08:21 PM
I'm thinking Fish oughta ban his 1st casualty - My vote goes for...........................................................................................................................................................................................................................................................................................................................................................DKET
Dan
08 Concours14
D
posted May 26, 2004 08:25 PM
The more ya play into it - the more he laughs (I'm thinkin).
worm~hole
posted May 26, 2004 08:54 PM
..fine...then we'll 'pretend' play into it while he's playin'...don't cost nuthin' anywayz....
-George Orwell
D
posted May 26, 2004 08:56 PM
Jeez....
DB
posted May 26, 2004 09:05 PM
I actually think that DKET believes all the things he says
Dan
08 Concours14
D
posted May 26, 2004 09:06 PM
I think that's the funniest part - either he beleives it or he's smart enough ta present it that way.
Either way, I see it as pure EV (like the interweb in general - DOH, in general LOL)
0.21729397773743 seconds processing time
