BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Where can I get this stand for the 10R? NEW TOPIC NEW POLL POST REPLY
runninhorn
posted May 24, 2004 11:09 AM
http://www.cooride.com/stand/stand.htm
anyone know?
  Ignore this member    Click here to send runninhorn an AIM message.
ysr50
posted May 24, 2004 01:21 PM
http://www.abbastands.co.uk/products.htm
ZX-10R.net
  Ignore this member    Click here to visit YSR50's homepage.
bovinespongiformencephalo
variant Kreutzfeldt-Jakob
posted May 24, 2004 05:16 PM
Get a piece of 3/8" x 36" steel round stock at the Homey Depot (or get fancy and find some 10mm drill rod). Put it through the swingarm pivot shaft, put jack stands under it, and lower the bike onto the stands off your rear stand. Get the stands as close to the frame as possible. Much safer than that contraption and yours for about $10.
Michael Lee
Purchase Ivy
posted May 24, 2004 05:31 PM        Edited By: Michael Lee on 25 May 2004 16:11
yea, its call a pitbull . . . sorry but I ment the type of stand you should get is a PITBULL (why get something that may become too complicated).
runninhorn
posted May 25, 2004 10:19 AM
um, no, its called a SUPERBIKE STAND
runninhorn
posted May 25, 2004 10:20 AM
yea, they arent returning emails, and I dont want to spend $20 to make a phone call over there.......
posted May 25, 2004 10:35 AM
They're doing you a favor. That thing looks like a disaster waiting to happen.
posted May 25, 2004 10:41 AM
Abbastands? Didn't they do a song called 'Can you stand by me'?
runninhorn
posted May 25, 2004 07:40 PM
how? It looks like all the others out there......
Michael Lee
Purchase Ivy
posted May 26, 2004 04:37 PM
It could double as a tire balancer?
posted May 26, 2004 05:10 PM
or a rotisserie for a turkey or ham?
posted May 27, 2004 06:46 AM        Edited By: bovinespongiformencephalo on 27 May 2004 07:50
Like what others? If all you need is to get the tire in the air, get a Pitbull spool stand and a set of spools. That is a tool you will use for the rest of your motorcycling life. The stand you're looking at is for unweighting the rear suspension for servicing the shock, linkages, etc. Not something you're going to need every day. It works by inserting conical pins into the ends of the swingarm axle. This has got to generate some spreading force on the arms that carry those pins. The arms look to be about 18" long and one of them is fixed with a hand tightened set screw. Do the physics. I have a set of jackstands that are height adjustable and cost maybe $15 for the set. A steel rod from the hardware store will run another $4. That setup is bullet-proof. You do need a rear stand to use it though.
worm~hole
posted May 27, 2004 09:38 AM        Edited By: worm~hole on 27 May 2004 10:39
...what another cool idea, bovineboy!...I'm just a steel rod away from your set-up...first the screen, now the rod!...thanks, dude!
who would do us harm.”
-George Orwell
posted May 27, 2004 05:15 PM
Keep the jackstands as close as possible to the bike. The 10R is quite young and can only take a 3/8" shaft.
0.28536987304688 seconds processing time
