BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Just put on a 16T front sprocket..... NEW TOPIC NEW POLL POST REPLY
runninhorn
posted May 21, 2004 08:52 PM
..........and it is niiiiiiiiiiice. Can tell alot of difference down low, and especially on hard acceleration, amd very pleased with that $23 I spent. I highly recommend in, and it only took about 25 mins to install. In case anyone else wants to order one, its an AFAM Sprocket, PART #28401........
  Ignore this member    Click here to send runninhorn an AIM message.
Drowland
posted May 23, 2004 04:39 AM
Is there more vibration in the bike when you changed the sprocket? I know on the 12R I changed the sprocket to a aftermarket and it didnt have the rubber groment in it, it vibrated way to much? So i used a zx11D sprocket with the rubber groment and the solution was fixed. Is there a rubber in the factory sprocket?
Michael Lee
Purchase Ivy
posted May 23, 2004 12:30 PM
Good point Drowland, will keep that in mind if I ever go down one.
CanyonCarver
posted May 23, 2004 12:53 PM
Agreed, that is a good point I hadn't considered. One more reason to add teeth to the rear sprocket instead of subtracting from the front, I guess.
Michael Lee
Purchase Ivy
posted May 23, 2004 01:10 PM
I just kinda prefer steel sprockets for the amount of street miles I would LIKE to put my bike. I would not even sweat the speedo difference.
posted May 23, 2004 01:37 PM
What??? Explain this to me like Im 5yrs old. No rubber comes into contact with the output shaft.
worm~hole
posted May 23, 2004 01:59 PM
...maybe the rubber just 'dampens' out or 'absorbs' some of the incidental vibration frequencies from that spinning front sprocket?...I dunno...I'm just guessing...my brain not so big
who would do us harm.”
-George Orwell
Drowland
posted May 23, 2004 04:40 PM
Worm Hole is right. It acts as a dampening device. So does the 10R have the rubber in its front sprocket?
runninhorn
posted May 23, 2004 04:42 PM
mine doesnt vibrate one bit.........
top shelf
posted May 23, 2004 04:57 PM
Just changed to a 520 kit, and there is no grommet. Haven't ridden yet to know the difference, but the weight savings combined was substantial.
salsa1
posted May 24, 2004 06:54 AM        Edited By: salsa1 on 24 May 2004 09:38
I ordered 16 front tooth sprocket from AFAM ;got talked into ordering steel rear 41 tooth also (stock 39) as sales person informed Kawasaki team has been chewing up rear sprockets.
I might need to order chain ;don't know just did at the spur of the moment and spent $43 or so extra dollars for little larger rear just in case.
Will find out soon if I need a larger chain;figure 16 front gives a little slack.
Still experimenting on all this for ZX-10R;could add 15 inch front for not too much money also if I choose to. I know that I have a very tall first gear to work with as is (stock)....
dket
posted May 25, 2004 07:20 AM
I also prefer the add teeth to the rear . It gives more leverage on the rear wheel making it easier to turn . Same effect as larger brake rotors .
0.27592301368713 seconds processing time
