BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Oil Filter change - question NEW TOPIC NEW POLL POST REPLY
dreadlord
posted May 18, 2004 10:44 AM
I just picked up my 10 and was looking at the filter placement. Since I will have a couple hundred miles on her by the weekend, I want to get a new filter on her. What have people found is the best way to keep the oil off the pipes? I see a ring/spacer welded in between two of the pipes. Can you put the funnel spout through it and catch all the oil with the funnel? Does it have to be a shallow funnel? Or do most just put alluminum foil around the pipes before hand? Any and all stories appreciated.
Thanks in advance,
Dread
P.S. - any help with convincing reasons why I don't have to sell the 12 would be very helpful as well. Keep in mind they have to pass the wife's smell test.
Just Did It!
zeta xray
posted May 18, 2004 03:19 PM
The aluminum foil works for me. I try to shape it to control where the oil drains. Easy and cheap.
Jammer
posted May 18, 2004 05:58 PM
I did it last weekend - used foil - learned that trick right here - rolled up the edges, slipped it through, curved it over the pipes, & no problem, not a drop on the pipes. To get the filter out you need to lift it up & through the 2 middle pipes. Quite easy, actually. You'll need an "end cap" type of filter wrench to loosen it though, at least I did, the kind that goes over the end of the filter & a ratchet extension goes into it.
kz2zx
Nobody in Particular
posted May 18, 2004 06:03 PM        Edited By: kz2zx on 18 May 2004 19:03
Ummm.. The 10R sucks for a passenger and rider with a passenger?
0.23475909233093 seconds processing time
