BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Service Bulliten question (Valve Adjustment & Shims) NEW TOPIC NEW POLL POST REPLY
RichTJ99
Newbie
posted May 14, 2004 01:19 PM
I just want to confirm that you do not need to adjust the valves or shims within the first 10K miles right?
Admin of http://www.zx-10r.net
  Ignore this member    Click here to visit RichTJ99's homepage.
alley cat
posted May 14, 2004 01:33 PM
first valve service is at 15000 miles...
04 ZX-10R-blue(Mr. Hyde)
C/F Micron high mnt.
i refuse to go timidly thru life only to arrive safely at death...
Bill...track head
posted May 14, 2004 09:01 PM
And that's something I'll prolly take it to an expert for...
Note I didn't say I'd be taking it to the dealer...
I'll buy the parts and everything needed, but don't plan on doing it myself.
DKET
posted May 15, 2004 08:12 AM        Edited By: DKET on 15 May 2004 12:01
On a new bike I do a valve inspection at the 1000 mile/second oil service . First oil service is <100 miles for me . You might be amazed at how the valves move around in a short time . Remember the engine parts are still wearing in now .
Funny how I hear about everyone getting their valves looked at . The steelership tells them they are all in spec . That means your bike sat in the service dept for two days untouched . On the second day the tech takes it to redline around the block for you . Later you get a call to pick up your ride . I have several friends that work in the service dept of steelerships . This all came from them . And not just one steelership either . I was active duty Army stationed all over the U.S. and southwest Asia . I've been to steelships from coast to coast .
If you don't beleive that , try to do your own valve adjustment . I know for a fact it takes more than 3-5 hours like the steelership says/charges . Turning the engine over so that the cam is on the heel then measuring all 16 valves . If you need to adjust the shims , you have to remove the cams . Remove the cam chain , cam chain tensioner , timing cover and so on . That then requires a total remeasure of all the valves when you think you have the correct shims installed . Also the cam bearings have a specific torque value . Wrong bolt torque means you are off on your valve spec .
Also you need a feeler gauge that has a 45 degree angle to it . You need to get down under the cylinder head rib that the valve cover sits on and exactly parallel to the valve bucket . Any feeler gauge angle to the valve bucket will increase the drag on the feeler . Meaning you will think the valves are tight even though they might not be . It's all about precision .
0.29505395889282 seconds processing time
