BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Dual Headlights? NEW TOPIC NEW POLL POST REPLY
RichTJ99
Newbie
posted May 10, 2004 07:30 AM
Dual Headlights?
Hi,
Has anyone figured a way or made a part or something to get both headlights working (aside from the high beam switch)?
Thanks,
Rich
Admin of http://www.zx-10r.net
  Ignore this member    Click here to visit RichTJ99's homepage.
D
posted May 10, 2004 08:20 AM
I met a guy last night that transplanted dual HID's into his but they were H4 bulbs and when we left, I really don't think they did mush more than stock (he had adjusted the high beam as low as possible and runs them all the time).
beansbaxter
posted May 10, 2004 08:43 AM
was that in a 10r though? i didnt think the housing was big enough...ive seen it done to a 12r, there is a post with pics somewhere around here, but the 12 housing for the bulb assys are much larger than the 10
crispin
posted May 10, 2004 08:59 AM
I keep my High Beam on all the time.
1) I feel a bit safer (I got hit about 10 years ago and still have not forgotten)
2) I fu#king hate when someone tells me I have a light out on the bike.
04 ZX10-R Blue
slightly mod'd...
frEEk
posted May 10, 2004 09:32 AM
there is a thread here somewhere discussing the dual headlight issue you may want to do a search for. some decent info in there.
D
posted May 10, 2004 10:42 AM
Sorry - yes it was a 10R.
There is a guy on another board that makes an H7 kit for about $2-300 (if I remember right).
There is another 10 around here using a BMW HID setup (not a clean install though).
beansbaxter
posted May 10, 2004 10:46 AM
yeah i think the one for the 12 was from a mercedes setup...
i also prefer to run high beam all the time...these new pia bulbs though, high beam went out on one, so i am forced to run low beam since i prefer to have both lights going all the time...
dont know if ill spend the extra dough for the piaa's but there actually the same price for a pair as getting 2 single stock bulbs from ron ayers
frEEk
posted May 10, 2004 05:12 PM
then u'r paying way too much on stock bulbs. u get them from any auto parts store for like $10 each max. just plain h4 bulbs. the phillips/sylvania silverstar (i think that's what they're called) are supposed to perform about the same, possibly better, and are something like $20 each.
frEEk
oh, that is for the 12, not the 10. tho the h7 bulbs for the 10 ought to be around $10 a piece too.
justoyz2
Justoyz Racing
posted May 10, 2004 05:21 PM
I haven't gotton mine yet, however, I will use a jumper(like on th e12) change the relay to work like the 12 light(both run all time and the high beams should work the same)
RichTJ99
Newbie
posted May 10, 2004 09:18 PM
justoyz - any place I could buy that relay? Does it "bolt on" to the 10R?
frEEk
posted May 11, 2004 12:09 AM
justoyz, the 10 does not have dual filament bulbs, so that wont do anything. I assume when you switch on the high beam on the 10 that both sides r on?
DB
posted May 11, 2004 12:16 AM
frEEk - yes
Dan
04 ZX10r (Track only)
08 Concours14
frEEk
posted May 11, 2004 12:31 AM
k, then that's all u can do without trying to stick some dual filament bulbs in there. dig up that other thread on headlights for some thoughts on why it may or may not work satisfactorily.
frEEk
posted May 11, 2004 12:32 AM
dket
posted May 11, 2004 12:34 AM
Holy SHIT , finally found a post where SWFT did not threadjack someone !!! Not even a "helpful" comment . All in fun swft .
crazyman1
posted May 11, 2004 12:37 AM
ya when you run it on high beam then one is brighter than the other, no win situation if you ask me as far as looks go.
DB
posted May 11, 2004 12:45 AM
swft must not be feeling well
Dan
08 Concours14
12RPilot
posted May 11, 2004 01:26 AM        Edited By: 12RPilot on 11 May 2004 02:27
Before you retrofit two filiment bulbs (or HID), keep in mind that the distance from element to reflector is critical for a proper beam. A lightbulb element that is anywhere but the "sweet spot" will just reflect light all over. In order to get a semi focused beam, they make the light bulb/reflector relationship just right. That's why you can't just swap any old bulb into different applications (or at least one of the reasons). Having said all that, you just might hit the jackpot and luck out.
D
posted May 11, 2004 06:35 AM
See the other headlight thread(s)
frEEk
posted May 11, 2004 10:18 AM
the other headlight thread: /board/viewthread.php?FID=19&TID=11878
Zed
posted May 11, 2004 11:12 AM
swft - you OK?
Live long, and Faster
catd11r
posted May 11, 2004 03:53 PM
Damn my head is starting to hurt.
Life's Been Good to Me!!!!!!!!!
worm~hole
posted May 11, 2004 07:51 PM
...how'bout removing the 55w lo-beam and installing a 65w lo-beam so that when you turn on the hi-beam BOTH beams are 65w (as in left side 65w / right side 65w) instead of 55w/65w?? (or 85w low/ 85w hi ...or 100w lo / 100w hi?)
who would do us harm.”
-George Orwell
justoyz2
Justoyz Racing
posted May 11, 2004 11:39 PM
With a light there's a .
(hot/ground) wire. In this case there are three wires You will need two three wire plugs. You can get them from your salvage yard from any bike that has dual lights or a single light bike(need two of them). There are three prongs on the bulb (1)is for the high beam. (1) is for full time running. (1) is the ground(blk/yellow). The high beam light has a red/white. The low beam has a yello/white>(this could be reversied not sure the bike isn't in front of me)
The bike should have two relays. (1) for high beam and (1) for low beam. On your present system the light wires has two wires. One hot/ground wire for the low beam, and one hot/ground for the high beam.
You will have to run jumpers from the high beam side to both high beam three prong plug.
You will have to run jumper from the low beam side to both low beam three prong plug.
I suggest doing the low beam side first. If this works, the high beam will work.
I haven't tested this,but I am 95% sure this will work.
You may have to change your fuse to ensure current voltage is present.
0.24536418914795 seconds processing time
