BIKELAND > FORUMS > ZX10R ZONE.com > Thread: need help rear tail/lights/wires NEW TOPIC NEW POLL POST REPLY
runninhorn
posted May 09, 2004 05:10 PM        Edited By: runninhorn on 9 May 2004 18:10
Need Help with Rear Tail/lights/wires
Just took my rear tractor mud flap and turn signals off and man does it look good without that thing. Anyway, im trying to figure out which wires actually need to be spliced together to integrate the turn signals into the rear taillight--here is a pic I just took--
The grey connector went to the license plate light, and the other two go to their corresponding turn signal. Any idea exactly which wires to splice to the 3 wires going into the taillight? If I had my wire tester on me i wouldnt have a problem, but the last guy I loaned it to still hasnt returned it. Any help would be appreciated.......
Also, snapped a few other pics, anyone ever thought of mounting their plate up under here somewhere in the black area?
and with all the talk recently we have had about the 4 holes and insert, I snapped a pic for others to see just in case they hadnt seen it with everything off......
  Ignore this member    Click here to send runninhorn an AIM message.
posted May 09, 2004 05:26 PM
What integrator are you using?
posted May 09, 2004 05:28 PM
Also, do you have a factory service manual? It's got the electrical schematics in it.
runninhorn
posted May 09, 2004 05:31 PM
Integrator? Uh, i didnt plan on using one, do I need one? I was just planning on splicing one of the turn signal wires into one of the RED or BLUE wires going into the rear taillight assembly. I was about to run up to WalMart and get a $10 light tester and then label the wires, then splice them--will this not work?
runninhorn
posted May 09, 2004 05:33 PM
no, just the owners manual.......
frEEk
posted May 09, 2004 06:08 PM
problem with just splicing it in like u'r suggesting is u wont have any turn signals when u'r applying the brakes. u'll need to get an integrator. u can get ones for trailers cheap, but some have reported problems with them. motorcycle specific models seem to be around $60.
runninhorn
posted May 09, 2004 06:13 PM
Thanks FREEK for the info......
posted May 09, 2004 06:34 PM
I'd suggest you get with someone who's done this before.
crispin
posted May 09, 2004 06:35 PM        Edited By: crispin on 9 May 2004 19:39
I mounted my plate in the black area.
I just pulled up the seat and pushed in two holes into the thin plastic using a scratch awl for the bolts I used to hold the plate up.
I put the bolts in from the top. Put the plate on and tightned up the nuts.
Then I bent the plate down some so it is easier to see from the rear.
It is vary easy for a car to see th eplate while driving behind the bike. (at least you won't get a ticket for not having a visable plate.
I still have to put a light on for the plate.
I am going to use a 90 degree LED light soon just havem't got to it yet.
About your taillight, it cannot be done the way you describe.
You must by some type of kit. It is not done that way at all.
04 ZX10-R Blue
slightly mod'd...
posted May 09, 2004 06:36 PM
Well said!
runninhorn
posted May 09, 2004 06:39 PM
trying to find someone locally at the moment, will go up to a local shop tomorrow and talk to their tech guy, If I cannot find anyone,ill just send it to MD Wright and let him do it for me, though id like to learn if possible in person/hands on......
runninhorn
posted May 09, 2004 06:44 PM
Thanks Crispin for the info, and thats the reason I posted/asked here before tearing into anything as I was unsure about it. thats exactly how I think im going to do my license plate, may just bend that plate BallMoto sends me this week and see if that will work someway, and then go buy some small LED's to light the license plate the same way Larry did here--
Said he got it for under $15 at KMart.....and looks like it illuminates it quite well.....
crispin
posted May 09, 2004 06:53 PM
The plate looks much better (IMO) mounted way up under the bike than the way it is mounted in this picture.
Also Larry what part of Florida are you in? I am in Boca Raton.
04 ZX10-R Blue
slightly mod'd...
posted May 09, 2004 06:57 PM
I like the idea of that light. Pretty effective, and goes with the plate, where ever you put it. Thanks for the pic, Runninhorn
runninhorn
posted May 09, 2004 07:01 PM        Edited By: runninhorn on 9 May 2004 20:03
I completely agree. On all my GSXR's I mounted it way up under there, and has always worked great. I had been considering moving it out and mounting it out back, clean, like alot of others here did, but think Ill go back to my old ways and mount it way back underneath there. I had always used a 4 dollar license plate light from Autozone before, but this time would like to use something a little "cleaner" and will try and locate a nice white/clear LED tomorrow on my day off....only thing i may have a issue with is where to mount it exactly and how much to bend the bracket back as im not too sure how far down it sags in the back with 220 lbs on sitting on stock suspen. settings, will have to play with it and see.......will post some pics when its mounted.......
runninhorn
posted May 09, 2004 09:10 PM
Ok, just got back from Wal-Mart, here is the only Taillight Integrator I found---
and here is a close up of the left side (in)
On the opposite side there are 4 Flat outs marked--
---GROUND
----TAIL
----RT TURN
-----LFT TURN
so its 5 into 4
(here is a closeup of the box it was in)
Do you think this will work?
I just went and bought a Light Tester, and here are the wire breakdowns in from this picture--
A)The GREY wire on the far left is the LEFT TURN SIGNAL
B)The GREEN wire on the RIGHT is the RIGHT TURN SIGNAL
C)The RED wire next to the yellow/black wire is the live wire
lighting the license plate light
Now, ive confirmed that the taillight integrators alot of people have been buying in the past is similiar to this, but not sure how close--do you think seeing this INTEGRATOR, it could work?
kz2zx
Nobody in Particular
posted May 09, 2004 09:23 PM        Edited By: kz2zx on 9 May 2004 22:23
horn, you need to splice/tap into the taillight and brake feed, too, can you determine if they're separate wires? I haven't looked at mine yet.
runninhorn
posted May 09, 2004 09:32 PM
Yes, they are--I think. I just took my light tester and the BLUE wire is the BRAKE light going into the taillight assembly, and the RED wire is the TAILLIGHT or constant light going into the assembly and im sure the only remaining one is the ground.Here is a vague sketch of what everything is-
Here is the LEFT side of the integrator, and the wires coming into it from the left--
(bike) (Integrator)
BRAKE---- -----BRAKE
TAIL------ ------TAIL
LEFT------ -----LEFT
RIGHT----- -----RIGHT
GROUND---- ------GROUND
Think its cool to hook em up like that?
And on the flip side,
(RT side/Integrator) (wires going into TAILLIGHT)
GROUND--- ---Black/Yellow Ground
TAIL--- ---RED Tail Light
RIGHT Turn---- ----BLUE Brake Light
LEFT Turn-----
Here is where im a little stumped, ive got to go from 4 to 3, so which do I combine?
runninhorn
posted May 09, 2004 09:34 PM
Just wondering if this could *possibly* work, and the reason for going to wal-mart is a guy that hooked his 6R up this way used a Taillight Integrator from Wal-mart, and compared it to some of the aftermarket ones and it did the exact same job, just $100+ cheaper.......Hopefully this is the same one, if not, oh well, nothing tried, nothing gained.......
runninhorn
posted May 09, 2004 09:39 PM
oh, and another FYI, while at wally world tonite, I saw this amber LED light, $8, about 3" long, took it over to the battery section and tested it out, and man its bright. I snapped a pic of it, and am thinking of going back and buying one to see (just in case this integrator thing doesnt work) if it will mount flush in those black voids where the Rear Mud Flap was mounted......here is the LED--
and here are the voids--
looks almost like it might work perfect......
kz2zx
posted May 09, 2004 09:43 PM
Horn, what effect are you trying for?
Turn signals work as turn signals only, dark otherwise?
Turn signals with marker lights, flash brighter when turning?
Taillight flashes with turnsignals (in either configuration above)?
I'm not an expert at this, having never done it, but there are only a fixed number of choices, I think.
Which one are you going for?
runninhorn
posted May 09, 2004 09:47 PM        Edited By: runninhorn on 10 May 2004 01:10
What im shooting for is basically to eliminate any external turn signals and incorporate it into my rear Taillight. And am just trying to figure out which wires would go into the Integrator, and which would come out of the Integrator, and then be connected to teh Taillight wires......
On all my Other GSXR's, I paid around $150 for each INTEGRATOR, took it to a guy, who did all the work on my bikes, and when it came out, the taillight was always on and constant, like it is now, but when you put on the right turn signal, the right bulb flashed, and the left stayed constant-and vice versa. When you hit the brake light, the light that wasnt blinking was acting as the brake light. To make this Zx10R work, ill have to fab up a custom circuit board I think.
That LED I just posted above was a failed attempt option in case I cant figure out this INTEGRATOR wiring.....or if it wont work........
kz2zx
posted May 09, 2004 09:54 PM
Hrm. You want to turn half (split longitudinally, so left-half or right-half) of the led's on for turn signals, but both halves to stay on dim for taillight, and both halves to go bright for brake, and brake and signal to flash one half between full bright and taillight bright?
If this is right, I think you'll need to get into the taillight LED assembly and cut traces on a circuit board and solder in extra leads for that. Which traces, I couldn't say without pulling mine out...
worm~hole
posted May 09, 2004 10:00 PM
you go boyeeeeee!...there's a 24-hour Walmart 10 minutes away from here....I'm gonna go over there and git sum' to 'speriment with!
...I was also thinking about gettin' a thin section of black plastic, cuttin' an approximate shape of the tray insert's floor dimension, and velcro-ing it to the bottom of the tray...this way, all the holes are gone, but your tray is unmolested...you could even cut inserts to fit flush into the rectangular/trapezoidal slots...black is easy...the other slower colors could be painted to match...I, too, think the flat spot aft the shock would be a cool place for a plate...
who would do us harm.”
-George Orwell
kz2zx
posted May 09, 2004 10:07 PM
Horn, I'm a goin to Chicago in the early morning, I'll catch up in the mid-evening. If I understood right, you need to split the LEDs into two groups, and treat each group like a single round light on the trailer - and whether or not the 'round light on the trailer' has one or two 'filiaments' you'll need to decide. Hope that makes sense.
0.32003402709961 seconds processing time
