bovinespongiformencephalo
variant Kreutzfeldt-Jakob
posted May 09, 2004 07:17 AM
Back out the compression on the shock. All the way out. It's a little over 5 turns. Maybe dial in a bit more rebound, but it's not critical. The spring rate should be adequate on the rear, the front I dunno. Set the sag and see if it's close. They say it's set up for a 150 lb guy. I'm 155 and the sag was good, although at the race end of the spectrum, right out of the crate. I haven't touched the front other than to verify the stock settings and it's working great. I'm running Rennsports which have a compliant sidewall. That adds a bit of spring and helps with the compression damping out back. With the 218's and three turns out on the shock's compression, my ass was pogo'ed out of the seat every time I ran over anthing bigger than a shadow.
