BIKELAND > FORUMS > ZX10R ZONE.com > Thread: For the suspension gurus.... NEW TOPIC NEW POLL POST REPLY
scott_in_fl
posted May 08, 2004 04:44 PM
This bike is primarily for the track. Ohlins damper, lowered 10mm up front, no ride height adjustment to the rear.
Last time at JenningsGP the bike develops a wicked wobble that begins when getting on the gas hard while leaned over. The problem was most noticeable exiting a high speed dogleg and getting into the throttle hard in third gear. Straight up, the bike accelerates fine, and at high speeds in a straight line, the bike handles fine. This problem is only when getting into the gas while leaned over.
I have two thoughts. Either the geometry is too radical and the problem is coming from the front (although this came from the Attack settings and is actually less radical than their bike as the rear should also be raised) or the problem is coming from the rear when the rear suspension is being overwhelmed (too soft?).
Interestingly, I put it back on the road last weekend and took my GF for a ride and the bike handled like it was on rails... perfect! She weighs 110lb. so that either tamed the geometry or kept the shock in check, or both.
Has anyone else experienced this, and what are your thoughts re: a potential fix?
TIA.
k bryant
Sponsor
posted May 08, 2004 04:57 PM
So many variables.... I'd only give you two thoughts for now, so as to not send you in too many directions...
Body positioning. Bar pressure. Acceleration is causing a "squat" effect, so your forks are extending and potentially less weight is on the front tire. If you're not completely "one" with handlebar pressure/input, you will cause the wobble to start by pulling/pushing on them to complete the turn. You can try a few things;
Get up over the tank/front wheel more; Try to be smoother with your handlebar input by using more leverage on the pegs and/or your inner thighs on the tank as you transision the corner.
Kinda hard to give you an answer on why you think it's better on the road and/or with your GF. I don't think I've ever been asked to figure out a potential "problem" with suspension when comparing apples to oranges.
scott_in_fl
posted May 08, 2004 05:21 PM
Kerry, thanks for your thoughts. This is definitely not a "riding style" induced problem. I came up on TZ250's and could teach a course about being one with the bike. But even without any body movement or bar pressure exiting a long drawn out turn, (staying off the side of the bike all the way until straight up), the problem is still bad. Unfortunately, this is a bike setup/design problem. I've heard that the Kawasaki race teams are also fighting with this thing to get it to handle at the edge. I'm just curious if others have witnessed this exact issue.
k bryant
Sponsor
posted May 08, 2004 07:39 PM
Like I said, there's so many variables. And a big part of it is how hard you're pushing it, and how hard you feel good about pushing it. Since you're an ex TZ250 guy, you can appreciate just how many variables there can be. When I took a break from Superbikes, I bought Erv Kanemoto's TZ750 and tried sorting it out for me to ride it from his last rider (Freddie Spencer). Needless to say, I finally tuned myself completely out of it and figured it wasn't the bike ......
Good luck. Hope you sort it out.
a
posted May 09, 2004 12:48 AM        Edited By: a on 9 May 2004 01:48
can you post on wat setings you were on? comp rebound and preload fr. and rear?
I have wobble only on straights now and thinkin maybe to litlle more comp on the back
ride it like u stole it
Big Daddy
posted May 09, 2004 01:21 AM
As mentioned there are so, so many variables to consider! so i'll share a bit of info i was fortunate enough to obtain.
A CCS racer was @ Vegas a couple of weeks ago with a 10r and was having some chatter issues with one particular turn and try as they might to resolve the chatter they couldn't until he came across this 'birdy' who suggested he try a 700lb rear spring and set the laden sag @ 22mm and whala the chatter vanished. One would logically think that 22mm is not near enough laden sag to prevent blistering a tire everytime out! but low and behold the tires held up well. The 700lb spring isn't allowing the bike to squat too much, which would in turn enable it to maintain enough weight on the front end to finish the turn without chatter.
BD
ice 1
posted May 09, 2004 11:14 AM
We've had the same issues on our race-only bike. A lot of shaking on hard acceleration coming out of the turns, and some chatter from the front mid-corner when pushing hard. Right now, I'm waiting for the revalved forks & Penske triple adjustable shock to show up. Then we'll know if it is more of a chassis geometry issue, or something else. I do think most of the problems are coming from the rear suspension.
High HP bikes like these will really squat the rear more under hard accel. I'm hoping the additonal compression adjustment on the triple will let us dial some of that out, but it will probably require a spring rate change too. It kind of makes sense with what was said earlier about less sag - the motor is bringing the back end down more than typical, so a little less sag could help.
larry hensch
posted May 09, 2004 11:17 AM
whats up scott in fla this is larry in fla usa,probally shoulnt reply on this post but dude sounds like you know your stuff planning a jennings trip can you please give some advice on setting the bike up ,tires ect only rode one time up there what a blast 03 gixer 1000 mich,pilots total rooky any tips would be appreciated .martinelli school is a possibility if you dont mind yoy can e mail me so not to crowd this post .i doubt ill experience this wabble you spoke of but thanks for any in put and your time,all ears people ! or all monior lol
  Ignore this member    Click here to visit larry hensch's homepage. Click here to send larry hensch an AIM message.
D
posted May 09, 2004 11:31 AM
I thought I read somewhere that the suspension has a feature to stop/reduce the rear end "rise" under braking - could this feature be hampering instead of helping when under race conditions?
Just a thought.
scott_in_fl
posted May 09, 2004 04:05 PM
Some excellent information beginning to come through here.
Ice, I had the midcorner chatter also, but quickened up rebound to help deal with it. My bike felt like it was literally jumping off of little ripples in the midcorner when pushing hard. I never noticed it on other bikes. But, it's as if the front is not properly riding over the back part of imperfections. Quickening rebound allows it to better track at full lean. I agree the fork needs to be revalved.
As for the wobble from the rear, it appears that a too soft spring may be at the heart of this problem. D, I didn't know of such a feature, but now I'm very curious.
Another thought, swingarm pivot location. Too much squat on acceleration could explain the great drive we get out of corners at street pace, but is becoming problematic at race pace. This is telltale of a too low pivot (relative to the countershaft). It would've been nice to have some adjustment here ala the ZX-6RR.
0.22688698768616 seconds processing time
