DKET
posted May 08, 2004 04:13 PM
? for the dyno experts
The smoothing factor should be on 3 right ? My dyno run was on 5 . Am I looking at low HP levels because of ? Does the smoothing factor perform the same function as the video bandwidth button on a spectrum analyzer ?
Also since the 10R has a ultra short wheelbase , do you have to move the front wheel stop towards the rear of the bike ? This is in effort to center the rear tire on the drum . Never checked to see if it was adjustable .
To start the run should the rear tire be slightly rearwards of perpendicular to the drum ? When you let the clutch out the bike lunges forward a lot . That way the tire would be centered on the drum while under power . Reason is that my rear tire would get smoking hot on the dyno . I saw the black paint was removed in front of the drum on the deck . I remembered to center the tire after I pulled the bike from the dyno , idiot .
k bryant
Sponsor
posted May 08, 2004 04:46 PM
The smoothing factor can be wherever you want it. The "standard" accepted is 3. It could read slightly lower on 5. If you went the other way and put in down on 1, you'd get the higher pitched spikes that would show a higher reading. But why? Leave it on the accepted standard of 3.
Moving the carriage forward or backward is only relative to the last bike that was tested. If the last bike was longer or shorter, then yes, you'll adjust it.
Center the tire on the drum. Make sure the front tire is securely fastened and tight against the front of the dyno carriage/shoe. Do some minor accelerations to confirm the position of the rear tire on the drum when the forks compress when opening the throttle.
I'm hopeing you're asking out of currosity. Your dyno operator should be fully schooled on these procedures... As far as the tire getting hot, that's perfectly normal (not "smoking" hot).
DKET
posted May 08, 2004 05:22 PM
Actually I was given from 1-4pm their DynoJet 250 all to myself . I could not beleive it but true . They strapped my bike on and went to lunch . After lunch they came back but never checked the tire to drum centering .
Mr. Bryant , you mentioned that the tire gets hot . Mine made the rubber ball up , hot hot . Is this what you mean ?
k bryant
Sponsor
posted May 08, 2004 07:33 PM
No. Little different deal on the 250. Since they are "loading" it, I could see the tire getting hotter and balling up the rubber. We use the pure enteria 200.
But unless you're leaving out some holes, sounds like you've got some pretty interesting "operators" there? I don't know how there "loading" your engine and/or "braking" it, but I can't say I've experienced any radical abuse to a rear tire on the dyno.
