BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Installed the Euro front blinkers last night NEW TOPIC NEW POLL POST REPLY
crispin
posted May 03, 2004 03:41 AM
Ok. They look great. Much better then the empty black triangles I had.
Anyway it was harder than I thought it would be.
The 3 self tapping phillips screws that hold the blinkers in are very hard to get to.
I cannot believe that is how they were designed to come out. I sure hope I dont blow a bulb. I wish I had dropped in a LED conversion bulb into the fixtures before I installed them.
I only put in 2 of the 3 screews on each side as I just couldn't deal with the front screw.
But I do like the look, so it was worth it.
04 ZX10-R Blue
slightly mod'd...
posted May 03, 2004 03:53 AM
Turn the bars all the way to one side and go in from the top. Ah, fuck it, yer good to go.
worm~hole
posted May 03, 2004 05:17 AM
self tapping screws?????
who would do us harm.”
-George Orwell
marco383
posted May 03, 2004 05:41 AM
I used a 1/4" drive ratchet with a phillips head socket. Still not easy, but doable from bottom with the bike on a work lift.
DeesKo
posted May 03, 2004 07:17 AM
Shoulda pulled out the inner fairing. It makes it 10 times easier. You have the colored outer fairing, and then the black inner fairing which houses the mounting points for the turn signals. That inner fairing pops completely out w/ the removal of a couple of allen head/hex head screws that you can get to from inside the front of the bike... you pop it out, disconnect the old light and then those 3 mounting screws are a peice of cake.
Just a suggestion for those with their new signals in the mail.
Rob
posted May 03, 2004 07:57 AM
Muzzy recommends pulling the inner panel
crispin
posted May 03, 2004 09:28 AM
I could not get to one of the allens to take out the inner.
Also alot of the problem is that I did this at home last night and all my good tools are at my warehouse.
I do have to kick myself a bit as I did not think to turn the bar to gain access to the one bolt that was holding on the inner panel.
04 ZX10-R Blue
slightly mod'd...
runninhorn
posted May 03, 2004 11:11 AM
any pics???
  Ignore this member    Click here to send runninhorn an AIM message.
DeesKo
posted May 03, 2004 11:20 AM
I'm assuming you meant pics of the signals and not of the install process. I didn't have my camera with me during the install, but its really simple. I used 1 phillips head screwdriver and 1 hex/allen wrench and I think that was pretty much it......
Rob
Greenzx
posted May 03, 2004 11:37 AM        Edited By: Greenzx on 4 May 2004 12:04
I have a question about this very issue...Does the clutch cable go inside or outside of the panel on the right side?
I'm asking because I put it back on the inside of the panel, and now when I turn the steering head to the right to full lock, the clutch cable hits the "black box" (don't know what it is) just underneath the upper fairing.
zx10Roger
posted May 03, 2004 12:16 PM
Damn that looks nice on the orange ,muzzy says on back order for 2 weeks.
Zammy
posted May 03, 2004 12:59 PM
Man, that orange IS the shite !!!
RichTJ99
Newbie
posted May 04, 2004 10:52 AM        Edited By: RichTJ99 on 4 May 2004 11:53
Greenzx - it goes outside.
http://www.bikeland.org/board/viewthread.php?FID=19&TID=11881
Admin of http://www.zx-10r.net
  Ignore this member    Click here to visit RichTJ99's homepage.
Greenzx
posted May 04, 2004 11:03 AM
Thanks RichTJ99,
Guess I should've used the search feature. I am glad that I'm not the only one having that problem.
MAVRIK
posted May 04, 2004 11:31 AM
Hey guys Z-POWER has them readily available. Just an FYI
Everyday is holiday, every meal is a feast....
runninhorn
posted May 04, 2004 11:36 AM
looks good, Z wants $86, and muzzy wants $99, decisions decisions.......either way should have em by the end of next week........
Oh,and that LED conversion bulb you speak of, where can I get one, and how hard would that be to do?
Also, anyone heard of a rear tailight/signal integrator for this bike? Would like to integrate the turn signal into the taillight if possible..........
marc zx-10
posted May 04, 2004 12:52 PM
To do a led conversion is simple you just have to go to a place like radio shack and get a amber high intensity led and a resister. the resister is to lower the voltage drop accross the led. then just solder the led and resister together and wire it in. presto you have a led conversion kit. If you are not sure on what size resister you need just talk to the guys there and they can help you do the math to figure it out.
UGADawg
posted May 04, 2004 09:41 PM
I just finished this job and I too say, Please dont let the bulbs blow out. Its about a 2 hour job at least for a backyard mechanic like me. I am happy with the outcome of this, but i did talk ugly while I was trying to do it.
runninhorn
posted May 04, 2004 09:59 PM
thanks Marc, going to radio shack in the AM.........
12RPilot
posted May 05, 2004 01:25 AM
One LED? That's enough? Doesn't Auto Zone or Pep Boys carry them?
crispin
posted May 05, 2004 03:56 AM
I would not go this way.
Every Motorcycle catalog has something like this.
This just replaces the normal bulb and has like 20 LEDS already on it.
Here is an example I found real quick.
http://www.jpcycles.com/ProductDetail.aspx?PID=340-009&cs=Harley
04 ZX10-R Blue
slightly mod'd...
0.2317521572113 seconds processing time
