BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Adjustable ECU for the 10R NEW TOPIC NEW POLL POST REPLY
TAFB
posted April 24, 2004 03:29 PM
the mailman brought kawasaki's accessory catalog for the 10r in the mail today. very cool stuff...the adjustable ECU (to adjust fuel, ignition, and throttle bodies?!?!) looked very interesting...can anyone shed any light on what kind of performance can be squeezed out of the 10R with this ecu? have any of the pipe mfrs made use of this ecu and what appears to have a wider range of things to adjust than the powercommander?
Warlord
posted April 24, 2004 03:43 PM
Where did you get the catalog?
TAFB
posted April 24, 2004 03:46 PM
came in the mail from kawasaki.
Michael Lee
Purchase Ivy
posted April 24, 2004 03:59 PM
Something you requested or just sent out?
TAFB
posted April 24, 2004 04:22 PM
just sent out. i assume everyone who bought a 10 will get one.
TAFB
posted April 24, 2004 04:29 PM
Here's what the catalog states:
Adjustable ECU -- allows fine tuning of fuel, ignition and secondary throttle body operation -- (price is $1119.95 for the ECU!!!; ECU to PC/Laptop cord (necessary) is $599.95!!!)
they also have a head gasket ($89.95); catalog states that the gasket is .05mm thinner for higher compression
Broken Wind
posted April 24, 2004 05:34 PM
lol....must be one hell of a cord..
chitty chitty bang bang
saltnuts
posted April 24, 2004 05:44 PM
and people think Monster cable overcharges. 24K gold inners and titanium outer shell whith platinum tips and diamons just for some BlinG BlinG!! Must have riped it from the spaceshuttle.
Life is to short to live. Twist the throttle and hope for the best!!!!
  Ignore this member    Click here to visit salTnuts's homepage.
12RPilot
posted April 24, 2004 07:33 PM
Their marketing people must be smoking their lunch.
NESBA #209
posted April 24, 2004 08:14 PM
Hmm... I betcha that it's more than just a cable. Prolly a junction box with the embedded logic for reprogramming the ECU.
palomartian
posted April 24, 2004 08:20 PM
Race parts are priced like that for all the brands. Racers get them for a LOT less.
posted April 24, 2004 08:25 PM
Yah, I helped Mike Velasco build a RC51...Seems like every part (cams, harnesses, FI, crank, etc. was a grand each. Oy year, almost forgot Ti valves, etc...
TAFB
posted April 26, 2004 05:47 PM
so anyone know what this adjustable ECU will do in terms of performance?
palomartian
posted April 27, 2004 06:12 AM
It's like having a set of carbs and a big box of jets. Great if you know what you're doing, worthless if you don't. It's mostly good for optimizing other modifications. On it's own it might be a few very expensive ponies.
GTracer
posted April 27, 2004 07:37 AM
It does fairly much in terms of performance. All stock bikes are running too lean of a mixture, to make sure the bikes comply with emissions regulations (hence the dip in torque around 5000 revs, which is fairly consistent on all bikes, as the emissions are usually measured at 5000 rpm).
If you change a full exhaust system to your bike, you usually need to do something to the fuel mixture. In carbs this means rejetting, with FI you usually have to do it by using either an adjustable ECU or an apparatus which alters the signal given by the ECU (eg. Power Commander, EMS, Rapid Bike, Motech, Techlusion). With some bikes changing a full exhaust system without adjusting the intake side of the engine, the fuel mixture can get dangerously lean, causing the engine to run way too hot. For example for the ZX-12R some kind of adjustment was required for the intake, when using a full exhaust system, to keep the warranty of the bike running.
Modern stock ECUs (for example the Mitsubishi unit used by Kawasaki and Suzuki) have some capability to adjust themselves in real time using the lambda-sensor of the bike. But usually this is not enough to keep the bike running with an optimal air-fluel mixture.
The good side of the Power Commander, when compared to some other FI adjusting units, is the popularity of it. Being so common, there's a helluva lot of ready maps for the PC, so pretty much anyone can find one that's suitable. Unless Kawasaki is testing and supplying ready maps for the Accessory ECU, it might take a little more work and time on the dyno, to get the bike running the best it can.
black ZX-10R
rubber pants
posted April 28, 2004 11:53 AM
Not according to the people at Powercommander.............they tell me they are taking as much as 20% fuel outta most areas of the lateset liter bikes.!??!?!?!?!? otherwise they be come "sluggish" (Now ................... we do not need that)!!
"Ya Gotta Have Big Ones!"
speeddemons.com
  Ignore this member    Click here to visit Rubber Pants's homepage.
posted April 28, 2004 12:56 PM
Gt Racer.... did you use the word "apparatus" in your post?
And what does this mean???
..For example for the ZX-12R some kind of adjustment was required for the intake, when using a full exhaust system, to keep the warranty of the bike running.
D
posted April 28, 2004 01:14 PM
Apparatus=thing (or close edamnnuff)
D
posted May 10, 2004 08:01 AM
Anyone got the part #'s handy for the ECU and cable?
marsh14
posted May 10, 2004 08:44 AM
ECU 21175-0044
cable 26031-0025
When a man steals your wife, there is no better revenge than to let him keep her
dket
posted May 10, 2004 09:33 AM
http://www.buykawasaki.com/Default.asp?strContentURL=site/PCProductCatalog/default.asp?intCatalogID=1
D
posted May 10, 2004 09:36 AM
Thanks - yes I know but I'm at work right now (basically laming out here - sorry, I normally look this kinda stuff up meself).
0.26130390167236 seconds processing time
